Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Colors converge will not adjust. What can be done?
    Novelist:
  • 85 Answers
Xpertis,
When the convergence will not adjust after you know you have set them correctly using your TV's convergence adjustment, your convergence board went bad. You can either repair it yourself with kits sold online (links below) but unless you know how to solder very well, opt for a repair guy. Your model will cost between $350 and $450 if you hire someone.
http://www.tvrepairkits.com/xcart/product.php?productid=20095&cat=0&page=1
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp-14g-43uwx10b61uwx10b-convergence-repair-kit/cName/convergence-repair-kits
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp15-convergence-upgrade-kit/cName/convergence-repair-kits
If you like to tinker but not dwell into the soldering world, try finding the same model for free or dirt cheap on a web site like www.craigslist.org that still works but like where a kid jumped into the screen!, and swap out the board.
Good Luck!
-Chris
Posted on Sep 08, 2010
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: Manual convergence -service mode
you have some resistors that are still open . If the ICs go a resistor or two usually go open and you cant always tell unless you remove 1 leg out of circuit and check that the resistance is within 5% of the rated resistance. Trying to adjust it by the service menu will only place extra strain on the new ICs and they will blow on you. The resistors are located right next to the ICs there are about 8 of them all I dentical. Very easy to spot.
Posted on Mar 27, 2008
Red shadowing is really annoying. Can anything be done to fix it?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tip
Convergence Failure Test
CONVERGENCE PROBLEMS
This is a very common failure on these sets and a fairly simple DIY fix.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some pics of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
on Apr 18, 2010 | Televison & Video
3D effect where the blue color is a little lower than the rest of the colors. More noticeable on words.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Here are some photos of convergence problems.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Philips 51PW9363 51" Rear Projection...
Green convergence will not adjust
May 23, 2010 | Panasonic PT-51HX42 51" Rear Projection...
It appears to be convergence issues. Red, green,
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Concave tv screen colors distorted just had tv repaired one year ago for same problem
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double visions, almost like 3d of all colors
You have a convergence problem, There usually are some limited user adjustments you can make. if these are available on your set they will be listed in the owners manual.
These adjustments are rather complicated. failing that the convergence IC's (chips) may need replacing and a full convergence alignment done. This is best left to a professional as the adjustments require some special equipment
Mar 13, 2009 | Hitachi 50UX57B 50" Rear Projection...
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Distorted colors
  • Screen looks 3D
Jul 26, 2008 | Hitachi 43FDX20B 43" Rear Projection...
JVC projection tv
Mike, convergence adjustments are in your menu, usually under "video" settings. You have to adjust red & blue onto the green, when you`ve done it correctly the "cross" will be pure white, if you cannot move either of the colors left, right, & up, down then the convergence IC`s have failed and will have to be replaced, hope this answers your question, BMW Rider
Dec 30, 2007 | JVC AV-56WP74 56" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
271 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
