I want to have closed captions on myTV. I use the TV remote for on/off and volume and the cable remove for all else. Clicking on the "cc" key on the TV remove creates nothing.
  • egallant Sep 09, 2010
    I have a remote for Wave Broadband. I now find that if I click on Menu I get a screen named "Video". I need the screen that lists the closed captions. How do I get to that one.I tried to move from Video but didn't work.
    Something is wrong with this communication, I haven't received an answer yet. I have Wave Broadband cable company and they tell me the problem is with ProView. I use ProView remote for on/off and volume, the cable remote for everything else. Come=on, it can't be that hard. "Menu" only gives me Video settings. How do I get to the "cc" setting?
    Guru:
  • 374 Answers
Do you have a remote for the cable box that was sent by the company you use?? what company do you use for your Cable?? What box/remote do you use(any info would be great!)
Posted on Sep 08, 2010
  • Robert Dahmen
    Robert Dahmen Sep 09, 2010
    The most important part I need to know is if you use a cable box to get your television or if you get you TV directly from the outlet in the wall??
    If you get you tv feed without your cable box you would use the remote for your Tv to set up closed captioning. If you use a cable box we would need to set it up through the menu on the box(not all cases but many)
    just let me know and we can try to get you CC from there. Something you can try now is look at your remote for your TV. Look for a button labeled "CC" try to press that and see if it gives you Closed Captions or options to add modify the setting for them.
How do I get the closed caption off my tv
I have found that Closed Caption in a function of your television service and not of the TV itself. We have had cable TV and used the menu function on the cable remote to find CC and select 'off'; we now have DirectTV cable TV and use the remote for the receiver to select CC and 'off' on the drop down menu of CC. We get to CC by pressing 'info' on the remote and a list of options appears at the top of the screen, one of which is "CC". Pressing the right arrow key moves the cursor and when on "CC" pressing "SELECT" creates a drop down list; "OFF" is the option to turn off Closed Captions.
Different types TV service (over the air with antenna will likely require changing the TV mode to CC off on none), but if you use cable (Time Warner, Charter, ATT Uverse, etc.) or satellite (Dish Network or DirectTV) then the tuner or receiver will likely have your CC option.
Feb 01, 2015 | Vizio Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Everytime ichange the channel ; a big black box pops onthe screen and the only way it can be removed is by clicking a volume button ; what can i do?
Tv still have it Closed Caption functions is on.U have the tv original remote wright?Yes.Look at ur tv remote control look for a button that said CC,push that button a couple times make sure like all CC1,2,3.. all to off.Closed Caption functions will turn off should have no more black boxes pops up onto the tv screen.Also used the tv remote control go into the tv menu go into Closed Caption funcions look for functions like Text 1,2,3... turn it all to off too.Should stop it for good,if Text also on too.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.
Jul 09, 2011 | TruTech T2000D TV
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
Unable to find how to access the closed captions section
Hi scorpiow2001
If you find the tools button on your remote you should find captions vision in the section of the menu hope this helps.. Cheers nikki
You can go to this link and download the manual for you tv
http://itg.beckman.illinois.edu/visualization_laboratory/equipment/multimedia/manuals/KDL40-46XBR2.pdf
Please take a few seconds of your time to rate my solution as i have taken time to answer your question the best i can Thank You......
Jan 17, 2011 | Sony BRAVIA KDL40XBR 40 in. LCD TV
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Jan 05, 2010 | Philips Magnavox 20MS233S 20" TV
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
335 people viewed this question
Top Televison & Video Experts
