Question about KitchenAid KGST307 Gas Kitchen Range
I own a KitchenAid KGRT607HBL4. The oven stopped working after we used the self-clean feature. The stove top works, so presumably the gas line is clear. The control panel lights up and the fan for the convection oven works. What steps should I take to diagnose and repair the problem?
catriver
  • 878 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
  • 126 Answers
SOURCE: KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Posted on Nov 22, 2007
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
jsrock516
  • 5911 Answers
SOURCE: Looking for a part KitchenAid DBL Convetion oven (12 years old)
Are you talking about the oven pan at the bottom of the oven? If so, the part number may be 1059318 and costs about $50. You can find parts for your range at repairclinic.com. Just type in your model number in the search window. There is an extensive pictorial part index with price infomration. Unfortunately, this part did not have a photo with it.
Posted on Feb 04, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
The self clean feature stops part way thro the cycle and knocks out the oven entirely. The gas stove top still works
Kitchen aid (now Whirlpool) has actually produced a defective stove here. Your problem is the thermostat in the rear of the unit. You can replace it yourself if you are handy, but that will not fix the problem that is built in to this very poor quality stove. If you ever try to use the self cleaning feature, it is most likely you will overheat the unit, and knock it out again and again.I wrote to Kitchen aid and received a very rude response from their "customer dis-service dept"...I told them theyir stove was defective and they wanted to sell me a NEW part for a high price, not even saying "sorry"...what a bad company! I urge all to stay away from Whirlpool products...they are junk!
May 22, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
I have an older magic chef I am trying to use the self cleaning feature. what am I supposed to have the two timer knobs set on? Or should I say the stop and start knob and the clock?
Start time should be set to current time of day (according to the clock on the stove) and the stop time should be set for at least two hours later. This will allow the timed oven feature to work for the self clean option.
***Keep in mind that if the clock does not work you will have to shut the oven off yourself after the two hours is up!!***
Good Luck!
Jun 15, 2010 | Magic Chef 31000 Gas Kitchen Range
After Self Cleaning, oven doesn't work
it appears that one of the elements may have failed. you will need to identify which one and have it replaced.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
Self-clean feature
hi .thanks for the question. f 3 on Frigidaire stoves, mean an open oven sensor. located in the oven top left corner, looks like a pen . replace the sensor. thanks the appliance doc
Oct 05, 2008 | Frigidaire FGF355FS Kitchen Range
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Feb 01, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
46 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
