Question about O'Neil Printers O'NEIL MF8I PORTABLE DOT MATRIX PRINTER SERIAL 8.5 X 11 [200190-100]
Green blinking (bottom) light. No paper feed or test print can be performed
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
O'Neil MF8i Infrared Printer Green light blinking problem,
Solution: There are two types of green light blinking problem slow and fast blinking so in case of slow blinking you should change the IC-LT1776 part location number on the board U14 and if the light fast blinking then need to change the part number U20 on the board.
Note: U20 Can be replace with working one only if you buy new one that will not work because its programmed by the manufacturer and normally U20 become faulty and U14 & U20 location numbers are for the old version board. With the new version board the ICs will be the same but the location number will be different.
Posted on Jan 27, 2016
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Oct 02, 2009 | HP LaserJet 1320n Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
My x1240 scans but does not copy or print. What do you suggest?
You will need to do the following diagnostic tests to determine the exact cause of the error:
· Remove the ink cartridges
· Perform the self test (test B below)
· Test the ink cartridges
A. To remove the ink cartridges:
Switch the printer on by pressing the green button.
Open the front cover of the printer. The cartridge carrier should move to the center of the opening.
Remove both cartridges.
If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand.
Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer.
Inside the printer, locate the silver metal carrier bar on which the print carriage slides.
Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion.
Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening.
Now pull both cartridges out.
B. To perform the self-test:
Disconnect both the power cable and the USB or parallel cable.
After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.)
Turn the printer off by pressing the green power button.
Hold down the grey paper feed button.
Turn the printer on by pressing the green button.
After the printer begins to feed paper, release the grey button.
Once the paper exits the printer, press the green button to turn the printer off.
If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. Please contact our Technical Support Centre for your service options. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below.
C. To test the ink cartridges:
Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place.
Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step.
Turn the printer off using the green power button.
Hold down the grey paper-feed button.
Turn the printer on using the green button.
If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly.
Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly.
If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase, or contact our Technical Support Centre.
IF u have problems u can use this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Mar 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
O'Neil Printers O'NEIL MF8I PORTABLE DOT MATRIX PRINTER SERIAL 8.5 X 11 [200190-100] Logo
78 people viewed this question
Top O'Neil Printers Office Equipment & Supplies Experts
k24674
Are you an O'Neil Printers Office Equipment and Supply Expert? Answer questions, earn points and help others
