Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
I have a LX466 Lawn Tractor made by Toro and I put on new Belts on the mower deck and now I don't know how to atach the two small springs back on it. Can you send me a picture as to how to replace them?
3 Suggested Answers
  • 248 Answers
SOURCE: why is my toro lawn tractor eating mower deck
most likely possibility is a bad pulley
Posted on Oct 06, 2010
  • 354 Answers
SOURCE: How do I change the
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
Posted on Jun 20, 2011
How to tighten belt on aToro LX460 V twin
it may have stretched and needs a new belt there is a spring tensioner that can only go so far
Apr 20, 2012 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Hourglass appeared on on my toro lawn mower and my blades no longer work.
Check for broken springs ontop of the mower deck these tensioner springs break after a while sometime you can use pliers to uncoil the spring a little and re-attach and use it untill you can get a replacement spring.
Sep 22, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
How to adjust the mowing deck
Click on this link from Toro. Then click on Operator Manual (English). Wait for the PDF file to load and then go to page 21. That page has detailed instructions and drawings for what you need to do.
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#manualsResultPage
Aug 14, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Lawn tractor does not move repl. both belts pull
What brand of mower? You most likely have a broken return spring on the drive system.
Apr 11, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Grass cutting blowing out from in front of mower deck.
Dull or bent blades can cause this. Make sure that the grass is not built up under the mowing deck. You can purchase new blades at a Toro dealer like www.arcolawn.com.
tell them Joe from Fixya sent you!
Feb 12, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
94 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
