Question about Zebra S4M Thermal Label Printer
The printer is only printing on the left 1/3 of the label and has a wavey edge at the end of the print.
  • kevin_nolte Sep 08, 2010
    Thanks but the issue was that someone bent the guide on the outside of the printhead holding up so that the right side never touched the labels. I have straightened the guide and retensioned the head correctly I hope and it is working fine at this time.
  • 22 Answers
Sounds like your print head tensioners backed themselves off some or got moved to one side during maintenance. Check to make sure they are in the correct position and are set to the right tension level to ensure proper print darkness.
Posted on Sep 08, 2010
  • S1LV3R
    S1LV3R Sep 08, 2010
    Well thats a little out of the realm of web based help, lol. No way i could have got that one without seeing it. Sorry i couldnt help you.
Won't print the leading edge of the label
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4208 Thermal Label Printer
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
When printing 1 label it will print but 5 blanks shoot out behind
Different reasons.
- the size of the label is wrong.
- You are writing too low on the label( too near the edge)
- You have to recalibrate the gap sensor.
Feb 14, 2011 | Datamax E-CLASS DMX-E-4204 Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Printer skipping labels
Your labels are narrow, and might not be aligned beneath the gap sensor.
Remove the cover and make sure the labels are loaded all the way to the left (toward the inside wall of the printer.) There's a "label Guide" that keeps the labels from wandering to the right. There are two thumbscrews beneath the label path. The thumbscrew toward the back of the printer lets you adust the "label guide", which keeps the labels from wandering away from the sensor (and the proper printhead position).
Move the lever clockwise to open the printhead and adjust the guide so it is slightly snug against the labels but so that you can pull the labels without much effort.
The thumbscrew towards the front of the printer allow you to position the gap sensor to detect the leading edge and trailing edge of the label, so the printer can . If your printer used to work OK, this might be in the proper place, but if it is loose, slide the thumbscrew left or right to center the sneosr between the edges of the label.
Jul 29, 2008 | Intermec EasyCoder 4440 Thermal Label...
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Zebra S4M Thermal Label Printer Logo
231 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
