Question about HTC HD2 Smartphone
My HD2 won't charge! The box about charging when connected to PC is unchecked. Changed SIM cards, trued everything. Also it won't connect to the internet. Well it did on the weekend and now it won't!
  • 1751 Answers
SOURCE: my requirement is htc hd2 to connect to pc
you need to get hd2 pc suite
Posted on Nov 28, 2010
SOURCE: HTC HD2 sense not getting
download HTC PC Suite and everything will be OK.
if you haven''t got that do this:
1- go to: software112.com
2- search this:
HTC PC Suite 2.0.33
Posted on Jan 09, 2011
piboy_05
  • 11 Answers
SOURCE: i can not connect my htc hd2 phone to my pc?
make sure you have the right software on your pc
Posted on Feb 14, 2011
  • 42 Answers
SOURCE: my htc hd2 will not
Dear sir call to you mobile network service help desk and asks to send setting Internet and when you receive msg than open msg and save setting and when you save setting. And select you network is default network but of you have noire network commotion add on you home so no need to make default .....and open Internet
Posted on Mar 09, 2011
SOURCE: I want to access the
try active sync->file->connection settings->this computer connected to (select the internet) also try checking the box for 'allow connection to one of the following' option.
Posted on Mar 28, 2011
Wi Fi Connection/AC connection
Go into your Control Panel, then Power Options.... change the setting for the battery, it may make your battery life less. Also, go into Device Manager and Right click on the wireless card, under Network Adapters, and go to properties. On the last tab it should have a power option.... uncheck the box that says "turn off to save battery life".
Oct 29, 2012 | Toshiba Computers & Internet
After charging W350i not recognising SIM says, 'Insert SIM Card'. But the same SIM card is operative in other mobile. How can retrieve Phone contacts? Please help.
make sure if sim reader is not pin damaged or water damaged? if problem persist i think you can connect your device without simcard and copy all data to your pc, then give some repairer to check maybe need to flash (if flash you will lose your data).
or try to put your mobile without battery 2 days and then switch on to see may be this problem solves.with S.E. this problem a normal.
Jun 21, 2012 | Sony Ericsson W350i Cell Phone
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Have fully charged batterey but can't seem to connect to the internet without the mains lead connected. dell inspirion B130 kind regards
in device manager, properties of the network card, power management tab, uncheck the box to let Windows turn the device off to save power. By default the NIC is turned off on Battery
Sep 20, 2009 | Dell Inspiron B130 Notebook
My pearl stopped taking a charge when my son put his SIM card it.Any ideas on why it would stop charging?
Charger pin may have not plugged in properly from both the end ..try charging it with the help of USB cable by connecting to computer and also check with the charging pin whether is there any faulty in USB cable or charger....
If everything is fine contact service center
Aug 13, 2009 | RIM BlackBerry Pearl 8100
Moblie phone repair
I have bought a new 6300 phone housing on eBay. changed housing front and back,new buttons. changed motherboard,replaced everything carefully and correctly. the mobile turns on and shows everything as normal,,,, but shows Sim card not registered , wont charge, it plugs in and show data protection or something????? and shows no signal. I have worked at plenty of mobile phones replacing parts , this is over my head please help thank you.
Dec 02, 2008 | Nokia 6300 Cellular Phone
HP pavilion(a220n) no connect to internet
Use the setup wizard in the internet optins and be sure that the box at the bottom of the LAN settings is UNCHECKED.
Nov 05, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Motorola RAZR maxx V6 won't turn on at all
It's dead. You have done everything you could do to fix it, so buy a new one or have it repaired.
It appears to be a known problem. There is a fix on the first link you can try.
Motorola RAZR maxx V6 won turn on at all Google Search
Mar 20, 2017 | Motorola Mobility MOTORAZR maxx V6...
Internet Connection
If you changed your SIM card, you should have the new SIM card/ Phone number settings for the Internet and MMS. Try deleting the old settings (from the previous SIM card).
If you are sure that you have the right settings. Check with the service provider, the problem could be at their end.
Mar 14, 2008 | Nokia 6300 Cellular Phone
Emergency Download/LG
mine does too i took battery out then back in it worked but now it syas that again. charge it up
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
HTC HD2 Smartphone Logo
448 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
