Question about Samsung RS2556 Side by Side Refrigerator
Refrigeraror is warm and freezer is cold. just
Refrigeraror is warm and freezer is cold. just happend. 36 degrees were flashing
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
How cold should refrigerator verses freezer temperature
In most cases you want the freezer to be as close to -20 F degrees as possible and the refrigerator between +36 to +38 degrees F.
Oct 07, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My sub zero is great Ive had it 10 years. Just recently it has started to run warm going up to 43 degrees and then drops down to 36 degrees for no reason. What could be happening?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 10, 2011 | Sub-Zero Refrigerators
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Samsung RS2556 Side by Side Refrigerator Logo
180 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
