Well when i bring up the game i can log in but it turns a bunch of different colors at the title screen i dont know what programs i need to run it but that might be the problem
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 349 Answers
Game software is corrupted. Buy a new one or try to re-install it
Posted on Sep 08, 2010
Every time i try to watch anything an error screen pops up saying "we are having trouble playing this title at this time please try again later or try a different title"
Most of the time. It actually not them having the trouble its the user. ( you). MOST of the time its because the connection between you and the server ( the thing that has the movie file on it ) is bad. Indicating either your internet service is bad. or your xbox doesn't have a good connection. Is there a download speed test on the Netflix application? if so run it and if you get at least 6 mbs and up then the connection is good. but any lower then its your internet that is the problem. let me know what happens
Jan 31, 2014 | Netflix
Screen freeze.
two work-around methods for those consumers who are experiencing the "freeze" issue: 1) Remove or disable the HDD
or,
2) Load three different Xbox 360 games to the main title screen of each game then load Major League Baseball 2K6 on Xbox 360. All three Xbox 360 games must be completely different before loading Major League Baseball 2K6.
Dec 25, 2007 | Microsoft Xbox 360 Console
Nintendo DS 95 Games In 1 Games Wont Work
yes, i know, it is multi game card, may there is something wrong with your 95 in 1 game card, and it can not compatible with your ds lite any more.
May 05, 2013 | Nintendo Pokemon Crystal
IS NOT CAMPATIBLE WITH WIN 7
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller and Ways to improve display quality.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Show settings for all users
Lets you choose settings that will apply to all users on this computer.
Dec 27, 2010 | Computers & Internet
My comp sometime when i start it up will not go to the log on screen instead it brings up something like a weiord scrabbed screen and it will freeze up on games and the color of the game will change a...
Your videocard is either not pushed in all the way or defective. Try to push it down into the slot. If problem still occurs, try a different videocard.
Jan 11, 2010 | E-Machines eMachines Desktop PC
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
What is title screen?
The title screen is the first screen that pops up shortly after turning the system on.First it will tell you the system and then the company who made the game...then when it finally pops up and says Lion King...that is your title screen.
Mar 07, 2009 | Disney Interactive The Lion King for Sega...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
