Hdd Hi There Due to problem with my old computer, i took my 80gb hard drive (xp pro installed) out and pluged in another computer as slave, computer recognized the hdd and gave it name E drive. but when i open my document and setting folder, message comes up it is not accessible.i can open other folders. please any one help to solve this problem, i have important documents in that folder. thanks
    Genius:
  • 1,027 Answers
Because the user settings on your old computer with the hard drive installed as master were password protected, your getting the error.
There may be other work arounds I don't know of, I just do a general search, files and folders, and then direct it to look in E:/
You might try the recommendations in this article
Posted on May 14, 2008
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Compaq Presario will not format Samsung 80GB hard drive.
Sir,
you are required to follow these steps below.
1 turn on your computer with HDD in it
2 Enter in to the BIOS by pressing F2 button
3 there entering in BIOS look for "Drive Configuration" it might be writen in some other words
4 there you will find ..."Hard drive SMART capacity" as enabled in box above.
5 Enter that box and Disable it.
6 Push F10 and reboot the machien.
Now you will be able to format , install etc on your hard drive hopefully
Oct 21, 2009 | Samsung (MP0804H) 80 GB Hard Drive
I want to use a 80gb hdd out my old xbox, externally thru my comp, but its locked & comp wont recognise it even tho it sees it being pluged in thru usb. So cant format as it not really seeing drive? so...
I suspect the harrdrive may be set as a Master and not as a slave. If you're familiar with jumper settings, change the drive to a slave and try that...
Here's a link to the WD Jumper Settings guide...
http://www.wdc.com/en/library/eide/2579-001037.pdf
Sep 20, 2009 | Computers & Internet
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Windows won't load or instal
Freezing of computers occur mostly due to shortage of RAM. But in ur case, 1GB is quite enough for XP. Since ur computer is freezing b4 even starting up, thus it could be a problem of disk drives.check if more than 1 drive have been alloted MASTER (Primary) or otherwise same priority. If u have more than 1 HDD, then the one in which the Opering System is installed should be given the Master Primary and the other as Cable select/slave. Likewise do it for the CD/DVD ROM or RAM (the CD/DVD RAM should be alloted the master and ROM as the slave). It can be done by the JUMPERs on the back of the Drives. See the exact setup on the drive surface.
Oct 09, 2008 | MSI K9MM-V Motherboard
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Acer aspire T310 desktop
hard drive patetion then setup your jumper setting work done.
Jan 26, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
