Question about Elcoman Kobra 260CC4 Shredder
I have a small go cart and would like to convert the max. out put power from 11kw to horsepower .
    Genius:
  • 1,218 Answers
Sorry thats not going to work with the motor from a shredder.
Posted on Sep 08, 2010
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
Jun 15, 2011 | Chevrolet Corvette Cars & Trucks
Model pm0525312.18 serial 914080230 engine runs good but the voltage drops of from about 125volts to 90 volts when you put on about 1500 watts. does this model have a voltage regulator? what is a bridge...
According to the parts pdf, there is no voltage regulator. Voltage is adjusted by the rpm of the engine. If your have a meter that reads hertz (Hz), you can set the engine rpm by adjusting hertz to 60 cycles (Hz). At 60 cycles the engine is running at about 3600 rpm. Most engines develop their max horsepower at this rpm. If you are loosing power/voltage and the engine speed is not dropping below 3600, than most likely could be problem with capacitor, brushes or diode (bridge diode). The diode converts ac voltage from stator to direct current to power the magnet (rotor). Check for brush wear and test capacitor for value printed on part. It should test with 5% of stated value. Diode can also be easily tested with meter. Good holidays
Dec 05, 2010 | Coleman Powermate Powermate 5000W...
What size breaker does the 11kw hayward comfort zone electric spa heater require?
It does make a difference as to input voltage. But usually at 11KW this would be a 220V unit and require a 50 amp breaker. 11,000W divided by 220VAC = 50 amps. 230 or 240V input the same 50 A breaker.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Hayward Comfort Zone Electric Spa Heater...
I need assembly instructions for a gorilla cart. Load capacity 1000lbs...max dump capacity is 400lbs.
You have got to be kidding? If you can't put that thing together maybe you should just take it back you don't need it that bad!
Aug 13, 2010 | Gorilla Carts 600Pound Capacity Outdoor...
Trying to identify chevy engine code and casting numbers
you wont find the horse power with an engine code. you can go to your delar and ask them to explain the code for you. its free.
the max/min HP is up to you think base modle v8 230hp, top from the factory 300hp
you can change that gratly buy going after market.
remeber for 5k you spend you should get 100hp out. min (that includes instalatin and yada yada
May 30, 2009 | 1983 Chevrolet K1500
1854-Yamaha V-Twin Motorcycle Engine
The horsepower of that mighty beast is exactly 100 horsepower (73.6 kW). Here's some of the other specs:
  • Engine Type - Air cooled, 4-stroke, V-twin engine, OHV, 4 valves
  • Displacement - 1,854 cc
  • Bore & stroke - 100 x 118 mm
  • Compression Ratio - 9.5:1
  • Max. power - 73.60 kW (100 HP) @ 4,250 rpm
  • Max. torque - 167.80 Nm (17.1 kg-m) @ 2,500 rpm
  • Jan 17, 2009 | 2006 Yamaha Roadliner
    37 people viewed this question
    Top Elcoman Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an Elcoman Office Equipment and Supply Expert? Answer questions, earn points and help others
