Question about Canon PC-940 Black and White Copier
Canon copier 940 trouble code EO? - Canon PC-940 Black and White Copier
  • Canon Expert
  • 1,326 Answers
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Posted on Sep 08, 2010
How can I slove earror EO, in my BW PC-940
You can have this Error Code resolved, I am just not sure that it would be wise. These are the facts. You have a 10 year old machine which has an EO error code which means there is a problem with the Fusing Unit. The parts required to fix the error code are anywhere from $150.00 to $250.00 depending on if you go with the whole fusing unit or just the Fixing Film Assembly which is going to contain the defective part(s). There is some dis-assembly of the machine required in order to replace the parts. If you hire someone to do this you are looking at another $100 to $200 in labor depending on who you call. So you could easily spend $250 to $450 to repair the problem. These type of small copiers are sold brand new at Office Depot and other stores now days for $100.00. They will also have a USB port so you can hook it to a PC and use it as a printer. I am in the repair business and have been for 27 years. I would not recommend that any of my customers make a repair to this machine of this magnitude. I have in fact referred 2 of them in the last 5 months to go buy the new Canon D340 instead of repairing the old one.
Good Luck to you and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Canon PC-940 Black and White Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Aug 19, 2010 | Canon PC-940 Black and White Copier
Where is the fuse on the canon pc-940 copier. It
Why would a fuse have any thing to do with a clicking sound? If the fuser or fixing unit was having a problem you would get a error code. Have you replaced the toner or drum cartridge any time? If so, was the noise there before? If it was not recheck the installation and if you put the old parts back in and you have no noise, it has to be the new cartridge.... Good Luck
Oct 14, 2009 | Canon PC-940 Black and White Copier
EO appears at switch on then machine switches off
EO is a error code. You have a problem with the fixing unit. You will most likely have to replace the Upper Fuser Unit....
Aug 21, 2009 | Canon PC-860 Black and White Copier
Says there is a paper jam but there isn't
if the machine goes straight into jam code once switched on, its usually a good sign a sensor has broken or it has fallen out.
canon tech
Mar 26, 2009 | Canon PC-940 Black and White Copier
My canon copier PC-745 won't power up it has error code EO
i think the problems is in the delivery roll,the rubber is need to be change with the new one
Feb 04, 2009 | Office Equipment & Supplies
Canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PC 940 Copier
Don't let it put you over the edge.. It will never be found... It has an electric counter or none at all. I believe you hold down the STOP/ CLEAR botton and it flash's in the copier count display
Aug 14, 2008 | Canon PC-940 Black and White Copier
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
179 people viewed this question
old marine
old marine
