Question about Tec Patio II Grill
I have a Patio II and one of the ceramic heads is filthy and clogged. Can I soak and clean this baby rather than mortgage my home for a new one ? :~) Thanks...David
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
You can try to remove the parts, soak them in Simple Green, wire brush with a tooth brush or brass wire brush. Should work just fine.
Posted on Sep 09, 2010
Has Patio II for Grills gone out of business? Need to replace our burner in ours. Any idea of where to get parts other than maybe ebay? Thank you so much
Assuming you are talking about the TEC Patio II grill. it is made by the Thermal Engineering Corporation of Columbia South Carolina http://www.tecinfrared.com/home.php. the burners are sold as complete replacment parts as well as pieces of the burner sold seperately. It has a ceramic insert as part of the infrared burner. You may replace just that portion if that is all that is bad. if this has failed on your grill I would highly suggest spraying the four bolts that hold it in place (visible from the top of the grill with grates removed) with a penetrating oil several times over several days before attempting to remove them. Mine came out just fine and the grill is 12 years old. I love this grill even though there is a built in 12000 dollar grill on my patio.good luck
Jun 10, 2011 | Tec Patio II Grill
3e black not printing every other colour works just fine and I just replaced the black with a new cartridge. I have had the printer for years and have never had this problem. I thought that the print...
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition
Mar 24, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Pages cannot be print
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 23, 2010 | Canon i80 InkJet Printer
It wont print and it is making a noise when the print head moves, kodak esp 3250
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Mar 23, 2010 | Office Equipment & Supplies
Does not print with new ink
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Mar 22, 2010 | Canon PIXMA MP750 All-In-One InkJet...
I have a Patio 1. For the last couple of years,
It sounds like your ceramic elements are cracked and will have to be replaced. This can happen when cold juices drip directly onto the red hot ceramic elements. The cracks can sometimes be hard to see. The latest generation of TEC grills have done away with these ceramic elements.
Feb 23, 2010 | Tec Patio II Grill
Print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
Hope this helps. .
Feb 08, 2010 | Epson Stylus Pro 7600 InkJet Printer
I have a Patio II that is about 10 years old. The
you can order new ceramic plates from tec it is only clipped in they should be able to send instructions
Aug 10, 2009 | Tec Patio II Grill
TECH II CERAMIC BURNER PROBLEM
just removed ceramic burners on my patio II-had to grind heads off of stainless stee bolts[ 4 on each burner],bolts do not have nuts instead they have theaded collers which have deteriorated and turn when i turned the bolt.used a 4" angle grinder-remove gas cylinder before attempting this!
Apr 11, 2009 | Tec Patio II Grill
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
Tec Patio II Grill Logo
295 people viewed this question
Top Tec Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Tec Grilling Expert? Answer questions, earn points and help others
