My ONN 15" LCD tv OLCD1504 is not or never really worked as the whole screen keeps going white so cant tune anythink in???
  • 579 Answers
SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
SOURCE: problem with Onn TV
I called the ASDA helpline and a lovely lady called Kirsty told me to hold down the pip/pop button. It worked fine.
(allways go to the source)
Posted on Feb 06, 2009
SOURCE: my brightness keeps resetting
i had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
Posted on Mar 29, 2009
  • 34 Answers
SOURCE: red screen
Sounds like you are having problem with main board and or the connection cord. Call your manufacturer and describe your problem and see if they are aware of this problem. Have seen plenty of TVs w/red pixelation and have replaced main board and av connector to fix the problem. hope this helps, j
Posted on Apr 08, 2009
SOURCE: Factory Reset for Onn TV from ASDA with no remote
There is no way to solve the problem without the remote. Thanks to the good people at ASDA customer service who can direct people where to order a replacement remote for £11. Alternatively the Acoustic Solutions (Argos own brand) remote also works with this telly.
Posted on Sep 30, 2009
My onn tv won't turn on the stand by blue light just keeps flashing !!! Does this mean it has gone to tv heaven ???
Often it can be as simple as bad capacitors on the power supply board, or if you cant desolder and solder replaceing the power board will usually solve a blinking power light for certain LCD tvs depending on model number but I would need your model number to further assist for your paticular situation
Dec 16, 2012 | Televison & Video
Tv turning off
Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 08, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Advent 5431 screen all mashed up ie cant workout what anythink says on the screen at all,when i plug in external monitor screen is ok..changed screen with a working laptop screen and changed inverter still...
Most probably you have a defective LCD screen cable. This is the only possibility left since you have changed the LCD screen & inverter, & an external monitor works fine. Check your LCD screen cable & replace it if necessary.
Oct 22, 2010 | Acer Aspire 4720 Notebook
Cant plug Pc into TV
Try holding down the fn key on the laptop and the dual monitor key (F5 or F8) for about 15 whole seconds. The laptop screen should go dark and the image should come up on the television screen.
May 15, 2010 | LG 32LG30 32 in. LCD HDTV
Need codes for tv
my onn remote control for a 42" lcd has broken i have a all for one remote control could you please tell me the code for onn so i can get my tv working by remote again
Nov 19, 2009 | Radio Shack (15-2147) Remote Control
DVD PLAYER
Hi
What you will need to do is to go and look for the latest codac pack download and install it
This normally solves the problem
Have a nice day
SlitWrists
May 27, 2009 | Coby TF-DVD7005 Portable DVD Player
Trying to enter code for universal remote on lcd tv
i have a 26in onn lcd tv kl26as25q model do you know the service mode.
screen has gone red.
thank you Dave
"i
i
Mar 14, 2009 | Televison & Video
Xbox/TV
Try using a scart switch, therefore you only have to use a basic scart lead from the TV to the switch. then plug your xbox scart into the switch and it should work
Nov 03, 2008 | Televison & Video
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
Codes for my sons TV
Hi there i also had this problem with my "onn" television and there isnt an "onn" make - apparantly it is the same as pacific or schneider so if you get a remote from asda theyre really cheap less than a tenner - i found that look up either schneider or pacific and the first code it says should work for your tv!hope this helps!
Sep 12, 2007 | Big Button TV Universal Remote
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
Electro Med Services...
