Question about Dell Dimension 4550 PC Desktop
No power to tower. Pressing power on button on front of tower fails. Is there some kind of reset or fuse to look for?
  • wandman Sep 08, 2010
    Have you tried basic trouble shooting?
    -- switching the power plug to a known working outlet?
    -- checking the plug connection in the back of the computer - or the power toggle switch in the back?
    (I recently had only half of the outlets die in my UPS backup battery.)
    If you're handy at all, you could try swapping a power supply unit in from a different computer.
    Sam
    Guru:
  • 1,082 Answers
There is no easy fuse. Did the computer get turned off at the back? Some power supplies have a switch on the top of the tower. Did the power strip get turned off? Have you verified that the outlet has power?
If this is not the problem, it sounds like a blown power supply. Do you have any lights on the system? If not, take the tower to a local computer shop and they can very quickly diagnose a failed power supply.
Posted on Sep 07, 2010
I held the power button to my directv receiver and it will not go off at all
You can try resetting the receiver by pressing the red reset button either on the side on the receiver or behind the door on the right side front of the receiver. If all else fails you can unplug the receiver from the power.
Dec 16, 2014 | Directv Televison & Video
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    The light on the power supply (back of tower) and light on the front button that turns on the computer flashes. This is with the power cord plugged in. The computer does not turn on when I press the...
    try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
    Oct 06, 2010 | HP Pavilion a622n (PC108A) PC Desktop
    When pressing the ON button it will not respond that fast it wont power up in short ... but waiting for a very long moment press it once again and it will be powered up .. what do you think was my pc...
    Could be a static build up on the motherboard. Disconnect the power cord from the abck of the system tower and press the power button in the front for 20 seconds.
    reconnect the power cable to the tower and now power on system.
    Thanks for using fixya
    proton
    Jun 09, 2010 | HP Pavilion A6010N (882780985575) PC...
    Pressing and holding the power button sometimes starts computer but more often than not it doesn't start while ac power is on. Please help!!
    This is may be the fault in the power button or bios settings under power - boot options. open the tower cover remove the power on connector. insert the reset connector to the power on pin and check with reset button pressed.
    Jan 13, 2010 | Computers & Internet
    DESKTOP WON'T POWER UP
    it is your power supply it needs to be replaced
    Jan 07, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
    Hp pavilion a305w isnt working
    sounds like it is in standby mode..........try pressing and holding the power button until it turns off fully. then remove the power cable to reset the power supply, wait for 5 mins then plug in and try again,
    it is also possible that you have a fault , possibly a failed power supply, it might be best to investigate that if the power reset doesn't work
    Sep 17, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    No Power / Start-up
    if the power button on the front of the tower has no indications, then you most likely have a failure of the power supply.
    Open the tower, and inspect for burnt wires. If you find no burnt wires, remove all PCI expansion card and all external connections, then connect the power cord and try to turn on. If no power, then you will most likely need to replace the power supply.
    It is the least expensive part to replace on a no power situation. If replacing the power supply fails, then the front IO panel (Power button board) is next, then the motherboard is the 3rd most likely part that may have failed.
    May 17, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
    No power to tower
    Try replacing the power supply.
    Oct 18, 2007 | Dell Dimension 4100 (-JM0TB01) PC Desktop
    Dell Dimension 4550 PC Desktop Logo
    347 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
