Need to know how where to install the relay switch.
  • 979 Answers
Hello merulli, hi, what particular product do you want a relay switch be installed?
Posted on Sep 07, 2010
My horn isn't working on a Chevy equinox but it's a new horn. What could be wrong with it..and my cruise control don't qork. Is it my steering wheel?
Was Cruise Control working before the New Horn was installed? The power supply to the Horn, (input to ground wire) is connected to the Cruise Control Module (CCM). This CCM is wired to the Relay Switch Box located in the Engine Bay. The Relay Box cover will have a Chart indicating what function each Relay coresponds to. Your local autoparts store (AutoZone) can test the Relay Switch, and you'll know (if any Relay) need to be replaced.
The CCM is also wired to the Steering Wheel, but first passes through the Clock Spring Coil, located just behind the Steering Wheel. The Clock Spring allowes for the Function Buttons on the Steering Wheel to have power while Steering Wheel spins.
The Clock Spring can malfunction or break, its rare, but this will cut power to the Function Buttons on Steering Wheel. If ALL the buttons on Steering Wheel dont work, then the Clock Spring is the Culprit. The Coil may need to be replaced.
The Cruise Control Module itself may have failed and also would cause a few or all Steering Wheel Functions to quit working.
But first check the Relay Switch Box and examine the Harness Cables connecting (Steering Wheel--to--CCM--to--Relay Switch Box--to--Battery Supply).
Also if Cruise Control was working before the new Horn was installed and now not working, then most likely the Problem is a bad wire connection somewhere and/or is a faulty Relay.
(Any Questions/comments jtobias1020@gmail.com)
Feb 26, 2017 | Chevrolet Equinox Cars & Trucks
Generac power management module install
Mount the transformer on the generator. Hard wire it into a 120 vac plug. Run wires to the module and connect to the coil on the relay. Now run the load you want to disconnect while the generator is running to the load terminals of the relay in the module.
Sep 10, 2016 | Generac GUARDIAN Air-Cooled Automatic...
Hi i need to know how to install the relay in the alarm system in car
sir you dont need to install a relay on a alarm system, because it doesnt use hi current and beside it doesnt turn off... it is always switch on. when you deactivate the alarm its just deactivated but not switch off... its just on standby mode... hope this enlighten you...
May 16, 2011 | Toyota Corolla Cars & Trucks
Lights dont work when turned on but running lights come on. Is there a light relay i need to change. 97 a4 2.8 quattro whats the relay number
Your headlight switch is melted internally - happens a lot on the A4. You need a new switch and install includes removal of the airbag and steering wheel. Not tough to do as long as you know how to work safely around airbags. If not, have it installed by a pro - airbags can kill you if you're unsure of what you're doing.
Jan 11, 2011 | 1997 Audi A4
Fog lights not turning on
Sounds good to me except, the switch light shout be on the relay primary circiut and light off until you turn it on. When you turn the switch on, it lights up and energizes the relay, the relay closes and completes the secondary circiut for ythe fog lights. VIOLA' I have a silverado. done deal thanks
May 28, 2009 | 2003 GMC Sierra
20 amp ignition fuse keeps blowing
I'm curious, does this vehicle have an alarm/remote starter? If so I expect the installer didn't wire it correctly ... it was an all too frequent issue, with inexperienced installers we had .... I would first suspect any add-on device first (if any) ... In answer to your question ... I know it does have a relay (Starter solenoid is a relay and built onto the starter) As far as it being a relay or the IGN switch ... I'm skeptical.
May 05, 2009 | 2000 Dodge Stratus
'86 corolla relay switch- how much and where can i get one?
there is not such a thing as ignition relay sw.send me an email to daddykouki@gmail.com. I can help you,i am an electromecanic with specialty in 1984/1987 corollas. If you send a tel. no. I can call you.
Mar 03, 2009 | 1986 Toyota Corolla 2 Door
Switch relay
if you want to do this with parellel with you switch as your starter starts you need your fan relay on .
just do parellel connection with starter.
May 16, 2008 | 1992 Ford Aerostar Extended
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
