Sony Bravia KDL-40S5100 Green light on, the right back goes off. Standy by light begins blinking red, in groups of two. blink-blink. blink-blink. blink-blink. help?
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
rustym62
  • 201 Answers
SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Posted on Apr 27, 2009
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony bravia 40 inch red blinking light when turned on green light shows but go,s back two blinking red what should i do
you might try washing it.
submerge the tv in the bath tub, use lukewarm water only.
then turn it on.
problem solved.
Sep 13, 2014 | Sony Bravia KDL-40EX700 40" LCD HDTV -...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Standby light blinks 13 times
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Mar 05, 2009 | Sony BRAVIA KDL-46W3000 Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
