Question about Initial DTV-262 26 in. TV/DVD Combo
TV will not turn on. Power on the wall socket is good. Worked one day and died the next. Is there a fuse some where inside which may be blown?
  • Initial Master
  • 8,457 Answers
No,power supply board have dying capacitors.That the board,where the power a/c cord plug into it.Power supply board,have dying about to be dead capacitors,these capacitors all way bulges up on it tops or puffing up on it tops.U know basic electronic and have tools?Check the power supply board and replaced these dying capacitors,will solved this problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Sep 07, 2010
Plug fuse blew.
Something is blowing the fuse if its out again, check for rails that are lower then they should be, chances are you will need a new power board.
Feb 08, 2018 | Televison & Video
MP750 Printer does not power on. There were no evident problems, was printing well one day and the next would not urn on.
1-check the power cable if it is twisted from both sides. or buy new power be sure it is inserted nicely into the printer socke.t
2- check the plug if there is any fuse! if it is blown up., change the fuse with the same amp rate.
3-check power source socket...try another power source wall socket.
4-keep long press on the power on.
I hope will do....otherwise something went wrong with your internal power supply good luck.
Aug 14, 2013 | Canon PIXMA MP750 All-In-One InkJet...
TV worked 1 day and no sign of power when turned on the next.Toshiba REGZA 42
if no any power indicator at the front panel, check for a blown fuse at the power supply board.
Oct 27, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Jvc tv av36230 was working fine one day tried to turn it on the next and nothing. its like its un pluged but it is. is there a fuse or something inside?
Yes, TV sets have a fuse inside (in a holder on the circuit board near the power cord connections) and it may be bad, but that's unlikely to be the trouble. Fuses seldom just go bad on their own, and if you find it's blown there's usually some other part that causes it. A dead TV is not always easy to fix, and you generally need the services of an experienced technician with the tools and information to track down the problem.
Have you tried unplugging the TV from the wall, letting it sit for a minute, then plugging it back in? This will reset the computer inside (if it's getting power), and sometimes that's all it takes. If not, you can take the back off the TV (MAKE SURE IT'S UNPLUGGED!) and check the fuse, but that's about all. As I said, if it's blown it will probably go again if you replace it, and if the fuse is good but the set won't come on it will need professional help.
Good luck, and thanks for using Fixya!
Jun 06, 2011 | JVC AV-36230 36" TV
Hi, My name is Anali and I recently purchased a Westinghouse TV from Target. I had it plugged into the wall and working one evening. The next day when I went to turn it on again the red button would...
Hi Anali. That sounds like the powersupply is bad. The tv has a one year manufactuers warranty. Take it back to Target and exchange for another one. Hope this helps.
May 27, 2011 | Televison & Video
One day just would not turn on, fuse maybe?
Possibly. However, I would try rebooting the unit first. Unplug the TV from the power supply for about 5 minutes. Then reconnect and try to turn the unit on. If it still does not work, plug a lamp into the wall socket where you have the TV plugged into. If the lamp lights, then you're getting power to the wall socket. If you have the TV plugged into one of those "power strips" check that it is turned on. If so, plug the TV directly into the wall socket. If it comes on, then you have a bad power strip. If the TV still does not come on, you'll probably need repair service.
Dec 01, 2009 | iLO 3200 32 in. LCD Television
My w4207 worked the other day, now it won't turn on. Not with the remote or the manual switch. Any history or help you can offer?
Unplug your tv from the wall for at least 20 minutes,plug power back in if problem is still present you may have a failed power supply inside the tv.
Could be as simple as a blown fuse on the power supply circuit or bad power transformer or other.
Nov 21, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Digihome digital terrestial receiver Model DVB 915 I sitched the TV set off at night and then turned off the electric switch at the wall socket for both the TV and Digi Box. Next day the digibog...
hello make sure power is off take the top off the digibox see if you've got a glass fuse inside if the fuse is black its blown .where the fuse is holders is it should say what the fuse is rated at ie 1.25 amp put a fuse in with the same amps if it blows again then you have a dead short in the circuit good luck
shaun
Jul 21, 2009 | Televison & Video
My Westinghouse won't turn on, please help!
I had the same problem...turned out it wasnt the TV at all. It was actually the wall socket. Seems I had to many things plugged into one wall supply. (i.e. xbox 360, wii, audio reciever, dvd player, vcr, etc...) after switching some other items to a different socket my TV works GREAT!! I hope your problem is this simple!
Apr 20, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Initial DTV-262 26 in. TV/DVD Combo Logo
179 people viewed this question
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
