Question about Nikon D200 Body Only Digital Camera
D200 focus dosn't work at all even with diffrent lenses
  • frieze Aug 21, 2008
    hi there has your problem gone away as i am in the same problem
  • 111 Answers
Is the AF/M switch set to "A"? Switch is just below lens release button.
Posted on May 16, 2008
I have a Nikon D200 and the auto focus isn't working on any of my lenses. What should I try?
There's a small contact area that has to make the electrical contact between the lens and body in order for the autofocus to work. Check this on the body for any damage or corrosion that may keep the connection from happening. There is also a very small mechanical connection between the two pieces - the D200 has the autofocus motor in the body itself - check for a small shaft that may be blocked or damaged as well.
Oct 20, 2009 | Nikon D200 Body Only Digital Camera
Auto focus problems using 18-200mm lens on D200
Your lens might need to be recalibrated. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Sep 28, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Can I use my Quantaray 28-90mm on my Nikon D200?
You should be able to. The Quantaray is a motor drive focus inside the lens and the D200 is a external motor drive. So yes you should. Put it on and see if the auto focus works.
Apr 23, 2009 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Lcd preview blank d200
you cannot "Preview" shots on the LCD screen with the D200. There is no Live View function. Newer models such as D300 and D90 offers such a feature.
Nov 10, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 refuses to auto focus with any lens it just doesn't do anything.
Does the camera body has a M/AFswitch? it would be located in front on the left side if that accidently gets changed to M your lens will not AF any more until you change it?? I know it sounds so simple but who knows!! Barry Brown
www.coralreefphotos.com
Oct 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
80~200 not focusing on my D200
If lens has aperture ring, set to min aperture before mounting (f22 etc)
With heavier lenses it is not so easy to tell when lens clicks in all the way to mount, Lens wont autofocus if not clicked in to mount just so. Also both camera and lens should be set to AF.
May 17, 2008 | Nikon D200 Body Only Digital Camera
Nikon D200
My first question would be what lens are you using - some lenses have auto stability features - please post lens make, type, model number and when you purchased it.
Dec 22, 2007 | Nikon D200 Digital Camera with 18-200mm...
REPAIR
OK guys, it seems to be the lenses motor which for some reason burns out. I put a Nikkor 50mm 1.4 mm AF(great lens by the way) on the d200 body and it works fine. I sent the 18-200 in for repair and I won't tell you how much they wanted to charge me to fix it, thank God it's still under warrantee. Suggest you all try out another AF lens on the D200 body to see how that works. If ok then send in your boom lens and pray that your not over the 1 year warrantee limit.
Nov 01, 2007 | Kodak EasyShare C875 Digital Camera
Nikon D200 Body Only Digital Camera Logo
55 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
