Instruction manual for ignis washing machine - Washing Machines
  • Dan Webster
    Dan Webster Sep 07, 2010
    front OR top load?
localwonder
  • 6784 Answers
SOURCE: Is it possible to download the user manual for the
Sure, you can retrieve the manual form the main Ignis support website. You will need to enter your model number in the provided space. You can also, retrieve you manual at this link below as well.
Click Here
Posted on Jul 09, 2009
SOURCE: instruction manual for Tecnik 9290 washing machine
i need intruction manual
Posted on Sep 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: ignis washing machine awd593
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 6277 Answers
SOURCE: can I get manual for
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 02, 2011
  • 6277 Answers
SOURCE: ignis washing machine operating manual
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You could also try the manufacturer's web site direct.
Good luck,
John C
Posted on Mar 10, 2011
How to operate IGNIS Bella B60 Washing Machine
Request operating instructions for your Bella B60 directly from IGNIS.
Feb 01, 2018 | Washing Machines
I. Need. Service. Manual. For. Ignis FL 800
Try.Googling (Ignis)( FL 800)(manual) without.parens (or periods).
Aug 01, 2016 | Washing Machines
Ignis website
how i get a manual for ignis fl910 washing machine?
Jan 23, 2014 | Washing Machines
I need user's manual for my ignis bella B60 washing machine
Sorry but FixYa cannot do that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 01, 2011 | Washing Machines
I have been given asecond hand Ignis 405/2 top loader washing machine, but doný have the manual. I simply cannot understand the washing symbols on the top. Can you help?
Hi and welcome to FixYa, I am Kelly
With great effort I found a quick start manual here that is not free:
http://www.user-manuals.com/quick-start-IGNIS-AWV4052.html
The link above is the only one I found that did not say
"The manual is available only in language(s): Spanish Portuguese"
It is the only link I found that saod the manual was also available in English.
I hate to make a referral as I am hoping you do not spend $8.99 for a manual in a language other than English.
Thanks for choosing FixYa,
Mar 23, 2011 | Washing Machines
Ignis ig 95 la user manual / operation manual
You will need to type into your search engine 'ignis washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 11, 2011 | Washing Machines
I need instruction manual for ignis washing machine model B96 LA
you can go to appliancerepairplanet.vstore.ca for a manual on that
Dec 09, 2010 | Washing Machines
Is it possible to download the user manual for the ignis washing machine model FL 1207
Click Here
Jul 09, 2009 | Washing Machines
Washing Machines Logo
544 people viewed this question
Top Washing Machines Experts
