Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
The display is showing a code "EO F-2" what does this mean?
  • Kenmore Master
  • 8,220 Answers
Shorted keypad most likely. Use a hot damp cloth to clean the sticky keypad.
Posted on Sep 07, 2010
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
Bosch water heater
People often think it is EO, but it is EC. Depending on the age and instalation, ithe may be a very simple repair. EC is a failure to ignite.
Jan 19, 2016 | Bosch Water Heaters
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
What does "Eo" mean? It comes up on my digital display
Eo means the control board is not programmed. Has to be programmed to function.
Jan 12, 2013 | Amana PTH123B25AJ Heat Pump Air...
I a samsung dryer showing error code eo the e is missing on the top line. It runs for 2-3 mins then shuts off showing code
If you take the unit apart by lifting the whole top off, you should see the techinical spec sheet for service techs. Make sure you unplug this first. E0 means that there is a problem with the controller. BUT that problem could be the control board or main board.
Aug 15, 2011 | Samsung Dryers
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Shows EO-F2-CODE
F2 means something is wrong with the keypad. Check that the keypad is firmly connected with the control board and press Cancel. If you get the code after a minute, replace the keypad.
Sep 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
What does EO means on LED of a induction cooker
i have longer induction , problem is EO error on the display..
i changed(IGBT,Fuse,Capasiter) what i do?
Jul 03, 2009 | Cooktops
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
77 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
