Question about Homelite Garden
I have a small homelite chainsaw.super EZ on the starter rewind it says automatic, but it has a manual chain oiler, it also has a knob that is labeled trigger latch, it appears also to be a compression release. The problem, it starts easy and runs good at high speed but throws a lot of oil out thru the muffler and dies when you try to idle it down. there's lots of oil on the chain even though you don't pump the chain oiler.IThe oil and gas is mixed at 32-1
    Top Expert:
  • Homelite Master
  • 50,058 Answers
Oil out of the exhaust means that the oil /fuel mixture is incorrect
change the mix to 50:1 ( for the correct mixture there should be a faint wisp of smoke at rpms)
the chain is oiled automatically when the chain is running and the oil will leak out if left with a full oil tank and unused
the idling problem most likely will be from the incorrect oil/fuel ratio or incorrect oil in use --it is not engine oil but 2 stroke oil
do not use e mix fuels in small engines
Posted on Jun 15, 2017
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: HOMELITE 245 CHAINSAW. IT WILL START
check gas tank vent and cap. Adjust carb a small amount ie. back out screw marked L 1/4 turn. If that does not work adjust screw marked "H" 1/4 turn out if no results adjust back to original position and go 1/4 turn farther in.
Posted on May 09, 2009
Editor925
  • 285 Answers
SOURCE: what is the oil-gas mix for a homelite superxl
16:1 ratio for most 2-stroke oil brands. A service manual recommends tro check the ratio marked on the bottle if using Homelite brand 2-stroke oil. For other oils, 16 parts of gas to 1 part of oil.
For 1 gal of fuel, that is 270cc of oil required to meet the 16:1 ratio.
Please rate this solution on FixYa!
Posted on Jul 16, 2009
dontbother10
  • 2220 Answers
SOURCE: automatic oiler on homelite super xl ao does not
Please see the clarification. Lou
Posted on Oct 05, 2009
dontbother10
  • 2220 Answers
SOURCE: auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 14, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
My homelite chain saw is not getting oil on the chain from the automatic oiler?
either a faulity oiler or oil lines cloged try using compresed air to clear the lines by blowing in the oil tank
Nov 15, 2011 | Garden
Need a manual for homelight textron super ez automatic chainsaw serial # 292740092
You can download then print your Homelite manual by going to www.homelite.com/service/product owners manuals the best way to do it is to right click on the material, left click save, put in in your Documents folder, then retrieve it to print if you actually have to hold paper. Good luck
Sep 23, 2011 | Homelite ZR10926 16 Chain Saw
Automatic chain oiler is clogged or not functional for homelite super 2 chainsaw
Remove the bar and chain, then clean the engine side case where the bar fits as well as the two small oil channels in the drive end of the bar that go out to the chain groove on each side. Start the engine with bar/chain off of the machine and look for oil oozing out of the side port when running at speed. If ok, reassemble the bar/chain, adjust the chain up to the lower edge of the bar, but free enough to turn it by hand. The teeth cut toward you on the bottom run. If you got no oil coming out of the side port, then you will need to check the oil pump, lines, and tank filter. This saw may have an oil volume adjustment screw near the lower run of chain, but in the case back or maybe underneath the case. Try turning it CCW to increase oil flow. Hope this helps!
Jun 28, 2010 | Garden
I just received a Recon unit of the Homelite model ZR10580 chain saw. Is there a bar oiler adjustment on the model ZR10580? In my opinion the oil delivered is excessive - oil drips from the bar.
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Once you find and open the IPL. If it has an oiler adjustment there will be an oiler adjustment screw listed. CW is usually less oil, make small adjustments of no more than ¼ turn. I suggest you contact them and check your Operator's Manual before making any adjustment. HTH
Lou
Nov 22, 2009 | Homelite Garden
Garden Logo
134 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
