Have a new blue ray with an lg hi def tv hooked up to a motorolla receiver only 1 hdmi port on tv how would i connect the blue ray
    Problem Solver:
  • 17 Answers
I am guessing your motorolla is a cable box, so I would just run component off that and use HDMI from the bluray, bc the picture that the motorolla boxes puts out is horrible anyway plus they have a lot of problems with HDCP. So just use component off that and it will save a lot of headaches
Posted on Sep 09, 2010
How to hook up Cables
Depends on what kind of cables you use. If you use an HDMI cable, then you simply connect one end to the DVD player to an unused HDMI port on the TV. If you are using a 5 cable Hi Def cable then you connect the outputs of the DVD player to the inputs of the TV color for color Red to red, blue to blue, green to green and red and white cables for the audio. If you are only using a cable with 3 connections, then yellow is for video out from the DVD to component in on the TV and then the red and white cables for the audio.
Mar 07, 2016 | Televison & Video
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Hi, Just bought new hdmi dvd. Tried connecting to tv but getting blue screen with sign reading "no signal". Please help.
you need to push your input button on the remote control and scrool down to HdMI 1 or 2 depending on what port you have it hooked to the port on the TV will say 1 or 2 on it this will give you your picture .
Sep 06, 2009 | Televison & Video
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
