Question about Yamaha RX-V2700 Receiver
RX-V2700 reciever clicks on and off and does not stay on. I'll do it manually or via the RF remote. It still does not turn on and stay on.
  • 142 Answers
SOURCE: Yamaha RX-V2700
Have you tried to see if there is a fuse connection on the back of your receiver?
Posted on Sep 20, 2008
SOURCE: reciever RX V800
I bought my RXV800 in late 2001. This amplifier is absolutely fabulous and I understand others -like me- being unhappy when it starts to fail. I have the volume control issue as well, it started to work normal for at least 5 years, then there was a period of 1 year that the volume neither went up or down when you turn the volume control and then finally a 3rd phase was that it more or less works reverse.
It is solvable and I repaired it myself for $ 0,0. The only requirement is that you are a bit handy. You need to open the box and find yourself a way to the volume control (and you know where this sits of course) because this is the one that needs to be repaired. This is 35 screws away from you in total but this sounds a lot worse than it is !
It is indeed the volume control that needs to be repaired. In an analog amplifier this component would contain a resistor (potentiometer) but hey this is a digital volume control and looks from the outside the same but isn't at all. You need to take this volume control with 5 contacts of its print with a soldering iron. Open this potentiometer lookalike and clean it with some absorbing paper. The issue is that there is a kind of oil/grease from the shaft (which is there in order to turn smoothly) which has leaked into the area of the contacts in the middle. Just clean it and turn 50 times with it in order to spread the remaining oil/grease if there would be any. Close it again, solder it onto its print and switch on the unit... you will see that it is repaired... not for 1% or 10% but for the full 100%.
Hope this helps !
Regards,
Dirk
ps : enjoy your RXV800 !
Posted on Oct 07, 2008
SOURCE: Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Posted on Apr 28, 2009
SOURCE: Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
i have no sound when trying to watch a dvd through my rxv2700. the dvd player is an insigna blue rya player. It worked at first but not now
Posted on Jun 20, 2009
Yamaha rx-v2700 digital A/V receiver will not read 3trb external hard drive when it is formatted on nts and also tried with fat32 format and does not read mp3 files. when plugged into usb port the reciever...
Hi. Is the HDD drawing too much power from the receiver (does it have its own power supply)?
You could look at the troubleshooting guide in the user manual here:
Yamaha RX V2700
Feb 14, 2018 | Yamaha RX-V2700 Receiver
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
Looking for codes for samsung BD-P1600 blue ray for yamaha remote
Samung's code for DVD to Yamaha remote is "0600" if that does not work, your Yamaha remote is a "Learning" remote and can learn your DVD's remote button by button. If you don't have your Yamaha manual, here it is.
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V2700_U.pdf Hope this helps, if you still have an issue, post a comment and I can help you some more.
Aug 05, 2009 | Yamaha RX-V2700 Receiver
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700
Sep 20, 2008 | Yamaha RX-V2700 Receiver
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 Receiver Logo
119 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
