Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
My refrigerator is not cooling. The fan is working, however it seemed to frost up.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
FREEZER COOLING OK BUT FRIDGE LOW COOLING
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor.
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | White-Westinghouse WRSZ28V8GM Side-by-Side...
Refrigerator is running, but it does not seem to be cooling. Freezer side seems to be ok. Have cleaned coils.
Not detailed description of your Refrigerator Problem?
1) Frost free system (Heater, Timer, Drain heater) properly not functioning.
2) Evaporative Fan not working (Check Air flow satisfied or not)
3) Compressor properly not working.
4) Thermostat (1,2,3 ) problem. (Rotate high and check)
Mar 23, 2011 | Kenmore Side by Side Refrigerator
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Ice build up and stops the fans...
heatman101
Sep 11, 2010 | Refrigerators
ELECTRICALLY WORING, BUT FROST IN BACK OF FREEZER AND SEEMS IT IS FROZEN AND FAN NOT WORKING. NO COLD AIR COMING IN AND EVERYTHING IS DEFROSTING
heatman101
Aug 25, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Kenmore side by side not cooling: The compressor seems to be running (it's hot), the compressor cooling fan is running, the freezer circulation fan is running, but not the least bit cool anywhere.
If everything is working, that you can see and hear, then I think you are low on coolant. A set of gauges will show you for sure or if you take the back panel off in the freezer and look at the cooling coils, they should have a light coat of frost all over. If it is low on coolant then they might have some frost on a few coils or none at all.
Dec 03, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
