We have a moble trailer 14x70 or 980 sq. ft.Model AUS-12C61F150L4(a6) was sold by your installer at this will cool the trailer a 2:00PM the unit will not cool this trailer. Quiston how big a unit do we need to cool this trailer?? I think your install sold us a unit not big enough right. PS. We leave in Tucson,Az
  • 455 Answers
Hello you need 18,000--24,000 BTUs minimum
Posted on Sep 08, 2010
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
I have a Westpoint split unit A/C Model WSM-24. Cannot get it to dehumidify. Can you tell me the settings on the remote to maximize this function? My office is nice and cool - but too humid!
there is most likly no problem with the machine itself. most likly its oversized. how many sq. ft. is the space. 700 sq. ft. per 12000 btu's is the norm. If its over sized the unit will cool the space quickly and not have the time to remove humidity like its supposed to. check your sq. ft. and on the unit you will see the BTU's of the unit and go from there. I hope this answers your question!!!
Sep 01, 2009 | Heating & Cooling
How to determine horse power of air conditioner
air conditioning units are measured in btu's stands for
(British thermal units)
6,000 BTUh to 10,000 BTUh will cool 400 sq.ft approximately
10,000 BTUh to 16,000 BTUh. will cool about 800 sq.ft approximately
16,000 to 28,000 BTUh will cool 2,000 sq.ft approximately
the idea is more but's the more cooling power it will have.
Aug 20, 2009 | Panasonic CW-XC203EU Air Conditioner
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
