Question about Car Audio & Video
Brake lights i have a 1999 ford fiesta zetec se my brake liguts flash and then stay on when i take my foot off the pedal and also come on when driving
Hi i had the same problem with mine, on the brake pedal under the dash their is a sensor attached to the pedal i jst used some electical tape and taped some 1p coins to it and this solved my problem hope this helps
Posted on Jun 15, 2009
Change light bulbs on my fiesta zetec 05 . I have a problem after replacement my tail gate light stay on have I put the right bulbs in
What lamps were you having a problem? So there is a lamp on your dash that says tail gate is open? There is usually a switch or sensor for that?
Maybe I misunderstood your problem?
If the tail gates lamps at the rear are staying on, no matter what you do, I'd have to check wiring diagrams for that lamp control.
Oct 16, 2016 | 2005 Ford Fiesta Zetec
What Causes abs light staying on, on 10 plate Fiesta Zetec
BAd wheel sensors, bad wiring to the sensors.
Aug 20, 2014 | 2010 Ford Fiesta 1.4
Ford Fiesta 1.2LX Zetec Engine model 1999...Passenger Side Electric Window suddenly stopped working, although the Driver's Side still works...could anybody tell me if they know what is wrong with
either window button or motor gone is ther any noises at all from the door cards like a thumping noise or is it dead all together but sounds like motor to me as a fuse would knock both sides off
Aug 17, 2012 | Ford Fiesta Cars & Trucks
Yellow warning light displayed on Ford Fiesta Zetec
yellow warning light means urgenyt attention to the brakeing system
Oct 17, 2010 | 2011 Ford Fiesta
How to cure a sqeaky clutch pedal in a Ford Fiesta
You posted this under Outdoor grills and smokers.
So my first suggestion would be to quit grilling and smoking in your car!
You did not say how many miles are on this car but my first suggestion
is but a can of PURE silicone spray and up under the dash lightly spray the pedal linkage. Do not use WD40 or the like as they are oil based and will attract dust, silicone will not.
You may have a nylon bushing getting ready to quit you or a cable that is wearing out.
If this is the case silicone will help for a while but sooner or later you will have to replace the worn part
Feb 12, 2010 | Fiesta Grilling
The orange engine light is flashing intermittently and its driving very lumpy
Hi, my dad has just bought a ford fiesta 2003 on sunday. His engine light came up yesterday and is continually on. He took it to a garage today and they said it was the catalyst converter. It costs £300-£400 for a new one. Its to do with the emissions the car is giving out.
Jan 12, 2010 | 2004 Ford Fusion
99 ford expedition, abs light stays on, front brakes seem to be dragging
When was the last time you changed the front brake pads?
Try this:
Keep the brake pedal pressed down and start the car, after it idles for about 10 second let go of the pedal. If the light comes on just as you leave the pedal - try pumping it a few times, turn the car off and pump the pedal some more until it becomes real hard.
Then, keeping your foot to the pedal, start the car.
Idle for about 10 seconds, let go of the pedal and press it again rel fast.
If the light doesnt come on again - it means you have a leak of some sort or that the main brake pump should be replaced.
Good luck.
Jul 11, 2009 | 1999 Ford Expedition
Ford Fiesta 1.25 Zetec - Gears not engaging so no drive power
Sounds like your clutch cable is caught. Try new cable.
May 19, 2009 | 2000 Ford Escort
Fitting brake light - fiesta zetec
There is also a push in socket at the top of the light and a clip at the bottom. When the screws are all undone insert a flat screw driver under the light fitting about 4 inches from the top (remember to use a cloth under the edge of the screwdriver to avoid marking the paintwork) you should be able to push it out now.
Apr 22, 2009 | 2001 Ford Focus
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
