Question about Maestro Lutron MAW-603-RH 3-way 600 Watt Preset Package
I am replacing an 8 year old maestro 603 master dimmer with a new one. There is one companion dimmer in the circuit.55 the old dimmer had a black, red, and blue wire but the new one has a black, brass and blue screw I have wired the house wire (black) that was on the dimmer black wire to the new black screw, the house wire (red) to the new blue screw, and the other house wire (black) to the brass screw the dimmer does not work and the led lights do not come on help wdmcdaniel@gmail.com
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
Blue to Blue, black to black, red to brass. Check that out...
Posted on Sep 08, 2010
  • BoomerP Oct 13, 2010
    Agreed, the blue screw should be connected to whatever house wire the original dimmer's blue wire was connected to. Swap them around and you should be fine.
Where does neutral wire go at end of circuit?
If there is only a white and black and ground coming into the box from the fixture then that white is probably really a black. The black is hot, meaning it has power. The white takes the power back to the light. If you can open the light fixture box and see what wires power the light.
Jan 11, 2016 | Lutron Maestro 150-Watt Multi-Location...
Can I reuse a Lutron Maestro MAW-603 dimmer in a 2 way situation?
you should be able to by hooking up the black wire on the dimmer to the hot wire(that comes from the electrical panel) in the wall box and the red wire from dimmer to the switch leg(the wire that goes to light fixture). if the dimmer has a white wire(nuetral wire) you will need to hook that up to the white wires in the wall box....CAUTION!!! when removing the old 1 pole switch, there should only be 2 wires and possibly a green or bare copper ground wire attached to it. if either of the 2 wires(not the ground) are white, IT IS MISLABLED OR MISCOLORED. DO NOT hook the dimmers white wire to it cuz it will fry the dimmer. If this is the case, then most likley you do not have a nuetral in the wall box but look anyway for a couple of white wires tied together with a wire nut and stuffed in the back of the box. if you find those than most likely thats your neutral(check with a wiggy or meter to be sure) and thats where the dimmers white wire goes. hook up the dimmers green wire to a green or bare copper wire in the wall box and then put a wire nut on the dimmers red w/white stripe wire.
Feb 16, 2014 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I replaced a standard single pole light switch with a lutron Meastro dimmer switch with remote. It does not work. I replaced the standard switch and all was good. This circuit is on the same line a gfci...
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
Mar 14, 2011 | Lutron SCR-20-GFCI - Dimmer Controls -...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I bought a MAW-603 with an accessory dimmer to be placed in a 4 way circuit. I followed the instruction on how to connect the accessory dimmer in the 4 way switch location but doesn't work. When I leave...
You are saying that you have a "4-way circuit". That means that you originally had two 3-way switches and at least one 4-way switch. ALL existing mechanical switches _must_ to be replaced with electronic dimmers in order for things to work correctly. You must have only _one_ master dimmer (MA-600) located wherever you desire. All of the other switch locations must be companion dimmers (MA-R)., NOT mechanical switches.
The MAW-603-RH comes with a master dimmer and one companion dimmer, so I suspect that you need to install one more companion dimmer.
Jan 16, 2011 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
How do I wire up a Maestro Lutron MAW-603-RH dimmer in a 4-way situation?
If you bought the 3-way package, there should've been two products included: the MA-600- and the MA-R. First of all, if this is a four way circuit, that means you currently have at least three switch locations. The package you bought takes cares of two of those locations, but to get the third, you need another MA-R. If there are more locations than that, each additional location requires an MA-R.
It doesn't matter which product (the MA-600 or the MA-R) you put at each location. They all wire the same.
At the 3-way locations (ends of the lighting circuit), install the dimmers just like you would a standard 3-way switch. The only thing I caution you, make sure that the blue screw on the dimmer is connected to one of the traveller wires going to the next switch box. Also note what color wire its attached to - because when you go to that next switch box, the blue screw of that dimmer needs to tie to that same wire. At the 4-way switch box, the most important thing to remember is this.... make sure all the blue screws are connected together (which is why its important to know WHICH wire is connected to the 3-way switches).
As long as you have enough product and you tie the blue screws together, it should work.
Nov 11, 2010 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I only need a single pole dimmer switch. Which product do i buy. I bought the smart dimmer system remote, but it doesn't seem to be right.
The photo shows the master 'smart' dimmer, but you purchased the remote 'smart' dimmer that is slave to the master dimmer.
So you are correct, that is not the correct dimmer for a single-pole application.
Cooper brand Aspire dimmers are available in 'Smart' dimmer and just plain old dimmer.
Smarthome has a plain old aspire dimmer
http://www.smarthome.com/21530S/Aspire-9530DS-600w-Slide-Dimmer-Desert-Sand/p.aspx
Google products also shows the Lutro Maestro dimmer
http://www.google.com/products/catalog?q=maestro+dimmer
Lowes and Home Depot have ordinary dimmers also.
Both the dimmer linked to above will work for your single pole application. Keep in mind, they also work for 3-way applications so there will be an extra wire.
Since you know the phrase 'single pole' I suspect the wiring for you will be a cinch.
If you need assistance with the new dimmer, add a comment and I will answer.
Oct 30, 2010 | Master Heaters Aspire Design System Smart...
How to program control with light switch
If I understand correctly, you have the Lutron Pico wireless control
And you have the Lutron Maestro companion switch or companion dimmer
Pico will not work with ordinary wall switch or dimmer >> it has to be a companion product from Lutron
I have read the PICO wireless manual, and it shows no instructions for communicating with the companion wireless switch or companion wireless dimmer
http://www.lutron.com/Products/SingleRoomControls/MaestroWireless/Pages/Overview.aspx
http://www.lutron.com/TechnicalDocumentLibrary/369-144f_Pico_Wireless_Control_SpecSub%20%286%29.pdf
I have read the 120V Companion switch manual and it shows no instructions for communicating with the PICO wireless control
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Single+Room+Controls&prodn=Maestro+Wireless%C2%AE
http://www.lutron.com/TechnicalDocumentLibrary/030865c.pdf
1-800-523-9466 for technical support
Technical support online appears at page bottom
Normally manuals give you some clue as to how the product works.
The PICO manual says it's easy to control lights (I guess it's easy for mind-readers)
There seems to be no answer or hint when working with the PICO.
I think Lutron tech support is where you go from here.
Let us know what you discover
Oct 22, 2010 | Lutron MRF-VCTX-WH Maestro Wireless White...
3-way dimmer dead
It could be a loose connection, and it could be a loose connection on the OTHER 3-way switch across the room. Also, verify that the dimmer is rated for the fixture(s): add together the wattage of each individual light bulb that the dimmer controls and make sure that the dimmer has a higher wattage rating. If it isn't, you might have burned up your dimmer (and risked an electrical fire). Hope this helps!
Aug 31, 2009 | Leviton Decora Light Dimmer Switch
Maestro Lutron MAW-603-RH  3-way 600 Watt Preset Package  Logo
211 people viewed this question
Top Maestro Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
