Question about RIM BlackBerry Pearl 8100
Battery drain on HP ipaq hx2400 series PDA. I understand you can down load a patch to stop the pda running programs in background or when off. But I dont know where to get the patch from? Hope you can help. regards Keith
Http://www.pocketpcmag.com/forum/topic.asp?TOPIC_ID=21004
Posted on Jun 07, 2008
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
HP Ipaq H4355 PDA charging problem
Use common sense and frequently charge the battery even when the device is not used.
Draining a battery fully often kills it permanently.
Mar 11, 2017 | HP iPAQ H4355 Pocket PC
Dead screen/touchpad
the touchscreen is most likely damaged, you can open the pda to see if the connectors are ok and so on but here is a replacement part for you
http://www.ipaqrepair.co.uk/view_product.php?product=540
Mar 25, 2008 | HP iPAQ HX2400 Pocket PC
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
  4. The Pocket PC resets and powers on.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
HP ipaq h6320
Here is a link to the full manual, however it says right in there to not disassemble so you will probably have to find someone's who has done it (maybe on a PDA or Ipaq forum) and ask them for direction. http://user-guides.mobiletopsoft.com/hp/hp-ipaq-h6300-series-user-guide/hp-ipaq-h6300-series-user-guide.php
Mar 28, 2007 | HP iPAQ h6320 Pocket PC
Some programs not running
Take a look at this similar post - http://www.fixya.com/problems-solutions/t115221,p477250/HP-iPAQ-hx4700-Pocket-PC.aspx Let us know if you resolved your problem Good luck
Jun 27, 2006 | HP iPAQ HX4700 Pocket PC
Connection problem
Have you considered software running in the background on your computer? Usually firewall/anti-virus software can block the connection. If you are running any Norton or McAfee products, it is likely the cause. Try disabling them, or boot into safe mode with networking support and see if the PDA responds from here. Safe mode loads a minimal set of drivers and no startup programs. Goodluck!
Sep 11, 2005 | HP iPAQ HX2755 Pocket PC
RIM BlackBerry  Pearl  8100 Logo
181 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
