Question about Frigidaire FRS26H5AS Side by Side Refrigerator
FPCL2CCB8S The fan that cools the compressor has gone out. The compressor works. Need a fan motor and fan for GE Motor LGE 0626284.
    President:
  • 1,796 Answers
Hi!!
Browse the following link to find and order your parts.
http://appliancejunk.com/forums/index.php?topic=2939.0
good luck! Don't forget to rate this port!!
Posted on Sep 07, 2010
My GE refrigerator is no longer cooling. Model GSH25JSTC SS. I just replaced the mother board WR55X10942 and it is still not cooling. Water dispenser, fan is working fine.
Is the compressor running? Is it any good? Is the thermostat control working and cycling the compressor on? Is the self defrost mechanism stuck in defrost cycle (shuts down compressor), etc?
Is the motor getting power?
U need to check all of these areas.
Apr 08, 2015 | GE Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
I have an gss221ibma side by side. the freezer no longer freezes but the refrigerator works. Also around the doorframe of the freezer it is quite warm and sometimes hot. please help.
Hello, pull the unit out away from the wall remove the cardboard or metal cover down the bottom which will give you access to the compressor area. Assure that the compressor fan motor which is the fan that cools the compressor is running if it is not then you will have to replace the compressor fan motor. Unplug the unit until the compressor cools if you leave the unit plugged in for a long time you can cause damage to the compressor itself. . If you do not have another place to store your food until you get the new compressor fan motor leave that cardboard or metal panel off the unit if you happen to have a large box fan put it in back of the unit this will cool the compressor until your new part arrives. I have had to wait 8 days for a compressor fan motor at one time and the customer I repaired the unit for had no other place to store there food. Note this fan has to be constantly running on the compressor until you are able to replace the compressor fan motor. If you have any further questions message me back Thanks
Rick
p.s make sure you have your model number when you order your part I tryed looking that model number up but it did not come up on the look up site if you need me to locate the part number that you would use to order the compressor fan motor message me back the make and exact model number of your unit Thanks again
Sep 08, 2011 | GE Refrigerators
Model# gsh22kgmcbb. everything thawing out.coil was covered in dust, cleaned as best i could. fan motor running kind of slow,i think.
Are you talking about the Condenser Fan at the back of the fridge next to Motor/Compressor.
If that is running slow it means the fan motor bearings and lubricant inside the fan motor has turned into a sludge which is a common problem. Need to replace the condenser fan motor. You can put a normal household fan behind the fridge to cool the compressor in the meantime.
Ash
Sep 06, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
GE profile refrigerator model # PDS22SCRRS not cooling. I looked in the back and condensor fan is not working. Should I assume that it needs a new motor or is it possibly the motherboard which I have read...
Check to see if you have 110 volts at the motor with the compressor running. If you do then your motor is bad - replace it. Also make sure something has not gotten in the fan to keep it from working. The fan must run to keep the compressor cool and from over heating. Be sure to put the back of the refrigerator back on when you are through.
Jul 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile fridge - stopped cooling. All I hear is a clicking sound. 3 years old. What can I do?
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
If the relay is ok the compressor is the problem. It has a 5 year warranty.
Oct 29, 2009 | Refrigerators
Outside compressor off while handler on inside, no cooling
CHECK WIRING MAKING SURE NOTHING FELL OFF BUT IF NOT REPLACE THE MOTOR BEFORE YOU BLOW YOUR COMPRESSOR
Jun 20, 2009 | Heating & Cooling
GE Side by side Refigerator an Freezer
Check to see if the condenser fan maotor, located at the back bottom is working or not, If the motor is not working the problem could be the main control board if this is an electronic contol ref. it will need replacement. Try using a fan and letting it blow on the coils and see if it cools down. Check the compressor to see how hot it is getting if you can. This is the most common problem. you could have something else. Hope this helps.
Aug 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
General Electric Refrigerator
Check the connection of the electrical harness to the fan motor. If it is fully connected and the motor still does not run replace the fan motor. The fan MUST operate at the same time as the compressor to properly cool the system. Spin the fan blade by hand with he power off. If it turns with any resistance the bearings are dry and in most cases the motor is replaced.
Jun 07, 2008 | GE Refrigerators
Ge frigde
if it is the fan at the compressor not running, the system pressure will rise and cooling will ******, verify 120 volts to the fan motor if you have 120 volts ac replace the condenser fan motor
Apr 06, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
