I have an Epson NX 110 Series Printer. Need to change all cartridges but cartrdge holder will not come to center & stop so I can do this. Can you help, please
Basti
  • 1447 Answers
SOURCE: Cartridge holder does not move to
Hi
have you tried pressing it down for 3 seconds? on the printer utility on your computeris there an option to change cartridge? pls check that, if all fails then that's a hardware issue. call epson for replacement.
Hope this help
Posted on Dec 20, 2008
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
cns assoc
  • 677 Answers
SOURCE: My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 31, 2010
SOURCE: Have an epson stylus nx110 printer and have to
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Posted on Mar 18, 2010
sourabh_035
  • 45 Answers
SOURCE: PRinter: Epson Stylus NX
i think some paper jam in your printer tray show you please clear all paper from back side your printer
Posted on Oct 11, 2010
When I try to change black cartridge in Epson NX100 the carriage will NOT STOP - flips back and forth. How do I get it to stop so I can remove the cartridge - Black is only one out.
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to allow you to change cartridges.
3. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
4. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
5. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer
NOTE: Beware that you must have all ink cartridges full because Epson uses color even when only printing black and white (lots of comments here about that scam!!)
Sep 05, 2011 | Epson Stylus NX105 All-In-One Printer
My Epson stylus NX 400 continually says "error..replace ink cartridges" I did and nothing changed.
Assuming the cartridges are new (since almost all of them have a chip on them)
1. Make sure you match color of cartridge with the correct slot. If same error, then
2. remove all carts. and clean both cartridge holder and cartridge contacts with alcohol.
good luck
Nov 06, 2010 | Epson Stylus NX400 InkJet Printer
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
Cannot get ink cartridges to stop at replacement Epson 300 series
If this is a new cartridge, open the front cover and remove all cartridges. Be sure the protective film has been removed from the cartridge prior to installation.
Inspect the contacts on the new cartridge for damage. Replace the cartridges in the correct place, close the front cover and power the printer down and then up again.
Hope this initial information and idea helps. Let me know for any clarification.
Jul 08, 2010 | Epson Stylus NX400 InkJet Printer
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Lost instructions. How do you change the ink cartidge on Epson sx200?
How do I change the ink cartridges on my new Epson NX 215 printer, I do not know how to move the ink holder.
Nov 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
SX 200
unplug your printer and the pull the cartridge holder to the center while the printer is in off state..it will allow you to install the new cartridge easily...
May 14, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Hi
Hope this help
Dec 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
jasbo
jasbo
