Question about 991 Responder LC3 SST Security/Remote Start System
How do I adjust the shock sensor to make it more sensitive???
Do not have instructions to set-up Seco Larm correctly.
3 different ways:
1.On-board dial for adjustment
2.A separate shock sensor with dial connected to alarm brain with 3-4 wires.
3.Newer models have a digital shock sensor which is adjusted by the remote
Apr 02, 2010 | Vehicle Parts & Accessories
Alarm too sensitive keeps draining battery unable too diagnose key phob settings
is the battery draining because the alarm goes off continually? if you can find the brain module, there is an adjustment knob for the shock sensor on the side opposite the main wiring harness. counter clockwise will decrease sensitivity.
Feb 21, 2010 | 473L 3-Button Mini Remote
Alarm goes off when loud car is near
The shock sensor is to sensitive, you need to adjust it from MAX to MIN move one point and try it knocking the car body if is still to sensitive move one more point until you desire is good, just don’t leave it to the MIN because if some one attempt your car braking the window the shock sensor is not going to act, but if you like to leave it to the MIN you’ll need to install a glass sensor for a better car anti theft protection.
Feb 08, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Anti theft system beeps constantly on a 03 z4
Sounds like you have an after market alarm system. Normally a factory alarm will not have a shock sensor. Its probably the shock sensor causing the constant beeping. If you think this is the case you can normally find the shock sensor under the drivers side dash secured to the steering column. It will probably have a light inside that comes on when it detects vibration. There will be an adjustment to make it more or less sensitive. Hope this helps.
Oct 03, 2009 | BMW Vehicle Parts & Accessories
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Continuosly alarm going off.
If its an aftermarket alarm check the manual to adjust the sensor sensitivity. If you don't have the manual check the alarm's manufacture website or contact them. Some times the shock sensor is in the antenna itself. There'll be a button saying something like, HI, MID, LOW. Set the sensitivity to MID or medium sensitivity.
May 06, 2009 | 1998 Acura CL
Prestige alarm sounds off all hours of the night why please help!
The problem could possibly be that the shock sensor is too sensitive. It may need to be adjusted. You will need to find the alarm module and see if it has a built in shock sensor or if it separate. Either way adjusting the sensor will help.
Apr 10, 2009 | Prestige 2 Button Remote Security System...
Make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Apr 04, 2009 | Vehicle Parts & Accessories
Car alarm
The shock sensor needs to be adjusted. Its too sensitive. There is small box mounted next to the alarm(brain/box) it has a small flat head screw on it, turn clockwise to increase sensitivity and counter clockwise to decrease. Good Luck
Dec 18, 2008 | 1995 Toyota Corolla
2004 f-150 alarm shock sensor adjustment
TAKE IT TO THE DEALER AND THEY HOOK IT TO A MACHINE TO TEST IT
Oct 18, 2008 | 2004 Ford F150
Open Questions:
See all 991 Responder LC3 SST Security/Remote Start System Questions
991 Responder LC3 SST Security/Remote Start System Logo
156 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
