Question about Frigidaire GLTF530DS Front Load Washer
I keeps saying e41 on the display screen. What should I do?
  • 15,935 Answers
E41 means the Door latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Showing on screen E41
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Sep 14, 2015 | Electrolux Washing Machines
I have an error code E41 on my Frigidaire ATF7000eso front load washer. How do I test to find the bad part
Good Morning friend, that's a great question!
I see that your Frigidaire washer, ATF7000ES0, is displaying an error code of "E41" and you would like assistance in troubleshooting that code. An "E41" typically stands for your main control board thinks the door switch is open. This could be a possible problem with your door switch assembly or main control board. I would recommend performing a reset just in case there is a miscommunication within the board and you can do that by disconnecting power from your washer for roughly ten minutes. If you restore power and continue to see an "E41" I would look over the door switch to make sure it is not damaged. If any electrical components need to be replaced I would suggest having a professional technician out to properly disassemble your washer. This will help you to avoid any future issues. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
E41
Control board thinks the door switch is open. You may need a new door switch.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
E41 is displayed
Hello mev1985 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 05, 2012 | Frigidaire Affinity ATF6000F Front Load...
I own a husky te449 2011 model and the clock keeps giving me ERROR E41 can anyone help me
Possible there is error on the clock processor, fault on the connector or fault in the board, could be a crack or damage.
You will need to remove the panel to have a view from where we can confirm the case. make sure all the connectors are tight
Nov 07, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
What do these codes mean E31-E41-E74-F31? can you help?
E31 = Shorted MAP cicuit sensor
E41 = Cam sensor circuit problem
E74 = Intermittent MAT
F31 = Display panels to BCM problem
This is to say if the vehicle is a 1991 Cadillac Deville
Then the Trouble Codes are as I listed above.
For future reference, the F is for BCM codes.
When entering the on screen diagnostics the display starts with one E for the PCM history, then E.E. for current. Same sequence follows for BCM codes starting with one F for history and F.F. for current ones
Mar 15, 2011 | 1991 Cadillac DeVille
Frontendloader keeps giving a E41 code and wont work
E41 means the control board thinks the door is open. If the door is actually shut then you will need to replace your latch assembly for sending a false reading
Nov 27, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My PowerShot SX120 IS keeps showing a e41 one
Use a card reader to download to a folder you create on your desktop.
Apr 19, 2010 | Canon PowerShot SX120 IS Digital Camera
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Frigidaire GLTF530DS Front Load Washer Logo
587 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
