Question about Sharp Vacuums
Motor just stopped. - Sharp Vacuums
    President:
  • 1,673 Answers
Some of the Sharp's have a fuse in by the switch. Could be blown fuse, bad switch or bad cord. The worst would be an open in the motor.
Posted on May 15, 2008
Just stopped working. battery ok.
Either the belt came off or the bushings went out of the motor. 9 out of ten times, its the belt. Check to make certain the belt is on the gear that drives the motor or is not worn or stretched. If that is ok, then take apart the motor and see if the bushings are cracked or broken. You can get them for $1
Nov 10, 2017 | Vacuums
DIRT DEVIL FEATHER LITE BAGLESS WILL NOT JUST STOPPED WORKING
Hello, if the motor stopped working it might be the cord, but the motor is more like it, the bagless vacuum have more issue, and if you don't replace the hepa filters offen then the motor goes. If I can help future feel free to call 1561-848-3387 Thank you, Teresa. Clean sweep Vacuums
Aug 10, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Dyson dc08 motor made rumbling sound and stopped
Hi there SmartAlec from NelsonVacuums.com.au here. Almost certainly it is the motor gone :(. Take off the lid that is under your bin and look at the filter underneath, if it has a black underside and a kind of burnt smell you will need to put a new motor in. If you happen to live in Australia you can get a motor from NelsonVacuums.com.au here is a link to the correct page. Hope this helps.
happy Vacuuming!
May 20, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor bogged down, smelled rubber, brushes stopped turning
This repair would require motor replacement, based upon your explanation.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Losing power on a carpet attachment
Does the motor stop or the brush roll? If it is the brush roll, then replace the belt. If the motor is stopping, then it could be the motor or the cord for the opwer head.
Mar 15, 2008 | Vacuums
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
97 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
