Question about Maytag Dryers
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the unit, getting the correct voltage, what is my next series of tests to determine the problem? Is it time to get a new one!
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
Heating element out, dryers runs
replace element but clothes still wont dry helpppppppppppppppp
Apr 21, 2010 | Maytag HYE3657A Electric Dryer
My maytag electric dryer all of a sudden stopped heating up spinning. the timer moves and the light is on inside though.
sounds like youve lost one leg of power to the unit, the element uses 240 volts and the motor and timer are connected one on each 120 volt leg to balance out the electrical load chk your input power for 240volts first
Sep 19, 2009 | Maytag SDE4606A Electric Dryer
Maytag HAV2558AWW stopped working all of a sudden. I was doing a load and had it only half filled with water.It will not drain, will not fill the rest of the way. Wont do anything.Any suggestions?
I determined that the problem had something to do with the timer control because it stopped all of a sudden and it would do nothing. I determined that it was not the lid switch because it will fill with water even with the lid up.I checked that the outlet had power. So it must be an electrical problem associated with the timer control. I took off the panel on the back of the timer and pushed the connection plugs together to make sure there was good contact. One of them must have been loose because it worked right after.I thought I was going to have to buy a new timer control module but it was just a loose connection.I have seven children and my washer and dryer work day and night. I am learning to become my own technician.
Sep 12, 2009 | Maytag Washing Machines
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer model HYE3657AYW
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Mar 04, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Maytag dryer
Your door switch might be defective and/or your timer might be defective. If it has a fuse inside it might be blown.
Oct 07, 2007 | Dryers
Dryers Logo
231 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
