Question about Lenovo 3000 V100 Notebook
Lenovo laptop with terrible beep-sound when power-supply are plugged in- and out
When the power-supply are plugged in- and/or out, my Lenovo laptop 3000 v200 makes this terrible beep-sound. Lenovo support claims that this sound is impossible to remove and that it is supposed to be there, but I then find it strange that nobody but me seems to be complaining about this issue on any computer forum. The sound is present both when running windows and e.g, bios... Any ideas for how to get rid of the noice?
Thanks M.K
  • 2 more comments
  • Anonymous May 18, 2008
    exactly as described above.
  • Anonymous Jul 20, 2008
    A BIOS switch to disable this annoying sound would have been nice!!
  • samarsh Aug 12, 2008
    Yes, "Impossible to avoid" -- what a ridiculous notion.
    Actually, it goes away when the computer speakers are on "mute." (Fn+Esc). Not a very good solution, but all I got.
  • srikanth0922 Jan 20, 2009
    When i am increasing the volume it is not increasing. some times beep sound coming continuosly and system hanging. after i restarted it is not restarting.only this problem is solving using os recovery.
  • 4 Answers
If you're using to Lenovo Ideapad U330 click on the volume setting and go to options: properties.
Select PC Beep and then adjust the volume to your desired level or mute completely
Posted on Dec 22, 2009
If your Lenovo speakers give a off signal constant ear piercing sound, if might just be audio feedback. It gets worse when you increase the volume of your internal speakers. This is what you do:
1. On taskbar, show hidden icons on the lower right corner.
2.Right click on RealTek HD Audio Manager.
3. Select Sound Manager.
4. Select Microphone tab.
5. Adjust playback volume to a lower level.
That should reduce feedback. This usually happens if the settings were tinkered with.
Posted on Sep 26, 2009
On Lenovo Thinkpad x200 Tablet this beep was enabled/disabled in BIOS. There are four options (low battery, system warning, etc.), you can enable/disable them individually.
Posted on Dec 13, 2009
On the contrary, i'm using ubuntu linux (though on a medion laptop) and getting the beep ... which i don't get when booting windows ... get that ...
Posted on Aug 23, 2009
  • 3 Answers
That's a really annoying sound! I made it mute using this trick:
http://www.myhowtoos.com/en/windows-howtoos/78-how-to-remove-a-beep-sound-on-the-laptop
Posted on Jul 13, 2009
  • 50 Answers
Commonly problem for continuous beep sound is the sound card or the memory card. Try to reinstall it or re-attach the sound card and clean the edge of it using the eraser. :)
Posted on Aug 28, 2008
Use Ubuntu Linux, and it doesn't beep at all. Fixed.
Posted on Mar 07, 2009
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
Ive tried to install a new graphics card in my lenovo thinkcentre pc but nothing shows on the display
Make sure your power supply is big enough and you have plugged everything in. Some video cards require power directly from the power supply with a special 4 plug cable. You can get adapters if your power supply doesn't have the right plug.
Sep 19, 2012 | Lenovo ThinkCentre A30 PC Desktop
My son was too playing with Lenovo X200 laptop and now the keyboard is locked - all keys make a beeping sound when pressing them! HELP please...
Unplug power supply from the laptop and remove the main battery, press and hold power button for 2 minutes to remove any residual voltage. Now replace all items and power on, if no change! check the owners manual for additional information.
Apr 07, 2012 | Lenovo ThinkPad X200 PC Notebook
I want lenovo g460 sound driver
Ensure you selet the correct OS and here it will be:
http://consumersupport.lenovo.com/ot/en/driversdownloads/Drivers_Show_2419.html
Just click on the link
Hope that helps
Dec 13, 2010 | Lenovo Computers & Internet
Lenovo IdeaPad Y510 totally dead
hi,
if the system is completely dead,theres a possiblity that the problem is with the power supply or the motherboard itself, try to use another AC adapter and if it still the same,contact manufacturer...
thanks
Jul 12, 2010 | Lenovo IdeaPad Y510 Notebook
T500 lenovo kepps beeping and wont turn on it just keeps beeping. i turn it off i took out the batter and still the beep is there and the computer wont turn on
remove the power supply and battery then remove the memory module, clean the memory gold contacts. a regular pencil eraser will do. return the memory then the battery.
Apr 19, 2010 | Lenovo ThinkPad T500
Problem in laptop
If you are getting a high pitch sound, and if it is coming from the base of the LCD screen, then it is most likely a faulty inverter. The inverter supplies high voltage to the CCFL lamp which provides the backlight for the LCD screen.
Replacement inverters are available from LCD Parts, use this link to get to their WEB site:-
www.lcdparts.net
Jul 28, 2009 | Lenovo 3000 G530 Notebook
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Lenovo 3000 V100 Notebook Logo
11,357 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
