Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Charging a canon battery in a car
I am going on a safari and the main sourec of power will be form the car, ie the cigarette lighter.
Can you charge the battery this way? can you get a cord which goes from the battery pack to a USB?
Thanks!
    Problem Solver:
  • 10 Answers
Just buy a charger set. You can get it online if you want. just go to amazon or one of those sites. Or just go to a Walmart. I am pretty sure that they will have it there
Posted on May 14, 2008
How do I know the battery status on my Stanley 350 amp jump start ? When I push the button it always lights up all 3 lights regardless of how much charge is on
I have a more basic version from Home Depot. From day 1, the charge indicator never worked correctly. Have had it several years now and probably by this time, the battery is just getting weak and needs to be replaced. I found that charging by the cigarette lighter doesn't work too well. Charging by the AC adaptor overnight is the best and I do it every 4 months. Once and a while, I test it by connecting to an old starter motor. If it spins at decent speed, the charge is OK. The cigarette lighter plug connection is also good to use when you need to change the car battery and don't want to loose all your radio presets. It backfeeds the system and keeps all battery powered systems powered when the main battery is disconnected.
NEVER run the engine without the main battery connected! Good way to burn out all your electronics.
Jul 07, 2014 | RoadPro Road Pro 12 Volt Dc Portable...
Cigarette lighters not working
Check for power at fuse. If power is there a break in the wire going to cig lighter is broken. If no power than there is a blown fusible link by battery. Check fuses under hood also
Jan 23, 2013 | 2005 Buick LaCrosse
Cigarette lighter does not work for charging in a 2009 Jetta
It won't charge in any other car, either. The SD10 is a camera, not a battery charger. To charge the battery, remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power source. See page 20 of this manual.
Dec 26, 2012 | Canon PowerShot SD10 / IXUS I Digital...
How do I charge my garmin 1300 gps
You can charge it using the car charger that came with it by plugging it into the cigarette lighter socket of your car and the narrow end into the back of the satnav. You need to have power going to the cigarette lighter socket. On some cars that means that the car has to be running. There's a little led (light) on the plug which shows when it's receiving power. Charging this way takes about 4 hours.
You can also charge the satnav using an optional mains charger which also takes 4 hours.
Finally you can charge it by connecting it to the USB port of a computer for 8 hours. Both the computer and the satnav need to be on.
There's a battery state indicator on the screen of the satnav which shows if the battery is charged or not, on the screen which shows WHERE TO and VIEW MAP. It only shows when the satnav is not connected to a power source so you need to stop charging it to view it.
Jul 13, 2011 | Garmin GPS
I just bought a garim nuvi 1360 and i forgot to ask how to charge the unit . first to plug it in the car lighter, what about the usb, could i tapp it in my laptop thru usb. pls explain better oscar...
There are 3 ways to charge your satnav. You can charge it with the car cigarette lighter socket or an optional mains charger both of which take around 4 hours. You can charge it through the USB port of your computer which takes about 8 hours. If charging with the computer both the satnav and computer should be turned on.
If charging with the car be sure that there's power going to the cigarette lighter socket. Some cars need to be running for power to reach it.
Jul 12, 2011 | GPS
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
My cigarette lighter won't work. Either the unit is burnt out; the fuse is blown or??? I need to fix this as I need a place to plug my cell phone/computer charging stuff. Any help is gr8!
if you don't need the lighter itself to light up cigarrettes, then get rid of the lighter and using a test light or meter, make sure there is power inside thesocket where the lighter plugs into. if power is already there, then your done and ready to go, if power is not there, then check for an open fuse in your fuse panel...some lighter go directly to the battery, in that case make sure that the wires are not broken somewhere between the lighter socket and the battery
Aug 15, 2009 | 2001 BMW Z3
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
No power to cigarette lighter
Did you look at the fues under the hood ? that is where the relays are also check them out too.
Jan 25, 2009 | 2000 GMC Safari
Cigarette Lighter Coming on but power not strong enough to charge anything
the two problems that you posted could be connected somehow by the alternator not charging because of the belt issue. so if you have a low battery, the cigarette lighter would have a low voltage also.
then on the ipod issue, the memory of the radio could have been lost due to removal of battery cables or the battery really went down on its voltage. just re-configure your radio to accept the ipod music.
tnx 4 using fixya,
drcool
Oct 05, 2008 | 1999 Mercury Cougar
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
