Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Display screen says : 1) the brake resistor fail 2)serial communication link between main pcb and inverter pcb is down What does that mean?
  • 4 Answers
I own this model the main nut spins of sometimes and the brake becomes lose just tighten the nut it only takes about 3 mins
Posted on Sep 22, 2010
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
Display shows F3
Communication Wired R/C.
Cause of error
1. Open/Shorted
2. Wrong Connection
Check point, Normal condition
1. Connection of wire
2. Main PCB voilt: DC 12V
3. Noise Interference.
Check points:
1. Check the wire connection, Open/short, Repair the connection.
2. Check the soldering state of the connection ( Soldered Poorly ), Replace the PCB if so.
3. Check the volt of Main PCB power source. ( DC 12V, DC 5 V ) replace the PCB.
4. Check the installation of wired remote controller. ( Noise interference ) A just the state of the installation.
Apr 07, 2015 | Heating & Cooling
Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
So, could be: main electronic PCB, display board or wiring.
Dado
Dec 13, 2014 | Electrolux Washing Machines
Krups XP7240 error OC
OC can mean faulty communication between the 2 boards, disconnect from mains & try again which you have probably already done. There is only 1 cable from the display pcb to the control pcb and that is to the top front of the side pcb.
OC can also mean the distributor is drawing too much power, if that's the issue just replace the distributor.
Apr 05, 2014 | Krups XP4030 Espresso Machine
Error E 732 0001
E732-0001 Error Code: Reader Controller PCB is faulty
[ Case in the field ]
Description
E732-0001 can be displayed when a communication error occurs.
Cause
In the field, this symptom occurred because the Reader Controller PCB was faulty.
Field Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). If the symptom still recurs, go to the Step 4.
4. Replace the Reader Controller PCB with a new one.
E732-0001 Error Code: locks up during copying
E732-0001 can be displayed when a reader communication error occurs.
Cause
As a result of inspection, it was found that this symptom occurred because of poor soldering of J1302-34pin on the Main Controller PCB (Sub).
Field Remedy
1. Make sure that the connectors are securely fitted between J1302 on the Main Controller PCB (Sub) and J502 on the Reader Controller PCB and that
there is no pinched cable.
2. If no problem is found, replace the Main Controller PCB (Sub) with a new one.
E732-0001 Error Code: Because of poor contact of SDRAM
Description
E732-0001 indicates that a reader communication error has occurred.
Field Remedy
As a result of inspection, it was found that this symptom occurred because the SDRAM was not securely fitted on the Main Controller PCB. So, remove
and insert the SDRAM once again.
Sep 26, 2013 | Canon imageRUNNER C3200 Copier
I have canon c2620n and when i turn it on give E 732-0001 i need help pleas
Description
Cause
Field Remedy
Cause
Field Remedy
Description
Field Remedy
Jan 31, 2011 | Canon imageRUNNER C3200 Copier
Problem with this unit
The washer has a field service mode. To enter the service mode: 1. Press the POWER key to turn the washer on. Make sure the HOME screen is displayed. 2. Press HELP. 3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. The display should display any recorded errors. write them down, including all MORE screens. This should be enough to get you started. Note: You must press EXIT and unplug the washer to clear all error messages and to activate the setup mode program. After repairs are made, you have to run a setup / self diagnostic check to get washer operating again. (prompts on screen when plugged back in and turned on) We can't ask for or give out email's, however if it slipped in an ask me maybe some scanned pages from a service manual might be had. This is most likely an involved exchange. Don't know how much info (ie: free time and advice) I'll be able to allow.
Oct 06, 2008 | GE WPGT9360EPL Top Load Washer
Sharp model LC-20B6U-S now has no sound or picture. While watching TV yesterday everthing went out. Screem appears to come on but no picture or sound.
By this description it sounds like you have backlight to the picture which means the power supply in the set is working and the inverter board which powers the screen is working. Your problem may be on the main board if this is the case. I have repaired this set for the same symptom with two different problems. First it could be on the inverter board, and second it could be on the main pcb. Once on this model a piece of metal heatsink slid down due to operating temp. of set and touched bottom of main pcb causing a failure of the sound and picture. Either way, if you have no on-screen-display you will be replacing a circuit board. If you whine loud enough to the mfg. co. they may help you. But good luck.
May 29, 2008 | Sharp Televison & Video
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
235 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
