Question about Motorola Mobility W375 Cellular Phone
Camera gone blank
After changing camera to night mode, now when i choose camera from the extras menu, the screen goes blank (like the phone was off). I still see the "capture" and "back" menu at the bottom, but the screen is blank. Once i flip the cover closed and open it returns to standard screen. Please help
  • Anonymous May 25, 2008
    had the same problem so I took out the battery and it fixed the problem when I switched the phone back on
  • bbargerrbr Aug 16, 2008
    The camera screen goes blank (like the phone was off). I still see the "capture" and "back" menu at the bottom, but the screen is blank. Once i flip the cover closed and open it returns to standard screen. Please help I have a motorola W375
Hi,thanks for that. I tried that one, but it didn't work. It still had the same problem. I've now sent it out for repairs. Found it was still under warranty anyway. Thank you very much.
Posted on Jun 04, 2008
    Brigadier General:
  • 7,752 Answers
Santy67 - have the camera check or change it.
Posted on May 31, 2008
There is a purple colour to the screen and the pictures I take are blank. The rest of the camera works fine eg. viewing photos taken, lens opens etc.
better option is to reset the camera to factory reset mode simple way to do it is just press menu & find reset option in the menu ,by choosing it you will bring camera to its those modes when you purchased it without disturbing the stored data in card.try out you will be sucessful "merry chrismas "& god bless you.
Dec 24, 2013 | Samsung Cameras
Camera screen has gone black and blank, what is wrong?
i think there is some serious issue with your LCD disply
May 04, 2008 | Olympus Stylus 720 SW Digital Camera
Can't find night mode
You can't find a night mode on the EX-Z40, because it is not there. This nice point and shoot camera does most of the things automatic and has little extra menu's like sport or night shots. And with a max of 400 iso, it will be difficult to shoot without flash in the dark. Although you can switch of the flash.
On the bottom site of the rail with the set knob in the centre you can chose the flash mode when in the rec mode. Then you can cycle trough the flash menu. Giving you automatic, off, always on or red eye reduction. Look on the top of the screen to see what you have chosen.
Oct 28, 2013 | Casio Exilim EX-Z40 Digital Camera
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
Cannon A530 View screen has gone blank
Usually this is beacause you press the button "visible", all camera have this button to choose the visible model of the LED, you can turn off it to save power to take more photos by view sight from the small sight window above the screen.
bp-511
Feb 11, 2009 | Cannon Cameras
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Blank Screen
Looks like CCD sensor problem. If this is the case your camera will work fine in playback mode but not in capture mode. Sensor has to be replaced.
Sep 04, 2007 | Olympus FE-170 Digital Camera
My screen is blank on all modes except playback and setup
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
Apr 30, 2007 | Nikon COOLPIX P4 Digital Camera
Motorola Mobility W375 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
