Question about Linksys Wireless-B Broadband Router Retail (DSLSBEFW11S4)
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
I tried initial install the linksys router b step by stepfrom install CD, but the install wizad repeat "try internet connection", but failure at final step.
the other steps were successfully pass.
I can not use the router reason this problem.
Oerating under xp, verizon dsl, there is no internet connection without router.
needs help.. thanks.
  • ipari21 May 14, 2008
    Oerating under xp, verizon dsl, there is no internet connection problem without router.
    Scholar:
  • 72 Answers
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
Posted on May 14, 2008
When doing initial setup router do you install the
Just need to setup router via 1 computer. If you used dhcp configuration, everything's pretty much
automated & taken care of ...no matter how many computers you have.
Jul 14, 2009 | Belkin Computers & Internet
Used to be able to connect using WRT310N
You should call Linksys tech support now. The router needs to be configured manually. The tech that you hired maybe not familiar on how to configure the Linksys router.
Jun 25, 2009 | Computers & Internet
I just purchased a Linksys WRT150N router & just followed initial instructions to install it. These instructions said to run the CD first before I do anything else. I did this & was left with their...
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
You have DSL, so you need to access the router's setup page and put your username and password in the PPOe settings.
See this page for instructions:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Also, your DSL provider is a good source of tech support and they will help you set it up.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Linksys Wireless-N WRT150N Router
How do i download install
it this for initial setup of your router?
you can run the setup cd that came with it and follow the step by step instructions, and hope it will work as smooth as possible, but if not, can you please provide the following:
Your Internet Service Provider?
The modem your using?
the exact model number of your linksys unit?
the Operating System of your pc
and your location.
thanks
Sep 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to setup the wireless router
If this is the first time you are trying to setup the router, might you need to install the router first.
otherwise my suggestion for you please contact your internet service provider / router company to get router configured to enjoy the secured wireless network.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
Aug 30, 2008 | Linksys Wireless-G WRT54G Router
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Installing a wireless-g router
use initial setup cd or call linksys technical support.
Apr 29, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-B Broadband Router Retail (DSLSBEFW11S4) Logo
134 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
