Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
I have a AV-56WP74. Recently it stopped working. If the unit is powered on, the speakers just thumped like a heartbeat. Then the power light just blinked. I found some solutions on this site. I found a 2.2 ohm resistor opened on the convergence power board. I replaced the resistor, plugged in the board, and the same thing happened. I can unplug the the 2 plugs on the left (looking in from the front) turn the TV on, and the unit works, audio is perfect, but the picture is bent, doubled, and basic convergence issues. What is the next thing to replace or check? IC's, other board,...etc? Thanks.
  • 505 Answers
Replace the ICs
here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Sep 09, 2010
Power light blinks , no picture or sound , just the speakers pulsating.making a heartbeat sound.
Sounds like the TV needs some type of serivice. But just to cover your bases try unplunging it from the power from the wall and let it rest for about 5 minutes. Then plug it back in to the power and try to turn it on using the power button on TV rather then the remote. See if that works. If it doesnt call JVC.
Sep 13, 2010 | JVC AV-48WP74 48" Rear Projection...
AV-56WP74
Check all of the large resistors on the convergence board. Usually at least one will be fried. Most likely, the 2.2 ohm if I remember correctly. Of course, make sure all the plugs are correct and plugged in.
Apr 21, 2010 | JVC AV-56WP74 56" Rear Projection...
AV-56WP74
Could be shorted convergence chips. There are two of them in the TV. If they short they will shut the TV down. One quick test is to desolder both of them...then power the TV on..if it fires up the chips were shorted and would need to be replaced. You can get a complete kit from www.TvRepairKits.com
Mar 11, 2009 | JVC AV-56WP74 56" Rear Projection...
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Our JVC 56in rear projection tv cut off and when we tried to turn it back on is makes a thumping sound and the blue light on the front blinks and the thumping sound gets louder... Help??
The problem is one of the video drive IC's on the crt boards is bad. These IC's are located behind the front speaker grille. The board connected to the bottom of the crt's will have these ic's on them. They will be screwed into a metal "heatsink" The part number is TDA6111Q
Nov 28, 2008 | JVC AV-56WP74 56" Rear Projection...
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
JVC 56in. is broken
id probably get a new model once they are past the 5 year mark its about time for a new one
Jul 22, 2008 | JVC AV-56WP74 56" Rear Projection...
No power after replacing convergence chips
Check the pins on the convergence ICs to make sure the solder isn't bridged between any two pins. You will need a magnifying glass to make certain.
Jan 19, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP30 Two Years Old. Up And Croaked
Hi What you are discribing is a condition call power supply overcurrent shutdown the TV is going into a protection mode to prevent further circuit damage you really to call in a tech with JVC projection TV repair skills to fix this problem for you good luck windman
Oct 25, 2005 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
