Question about Lowrance LMS-330C GPS Receiver
LMS-334C, WHEN TURNING ON THE UNIT, BACK LIGHT STAY'S ON FOR ONLY A FEW SECONDS, THEN GOES OUT FOR GOOD???? PLEASE HELP!
2 Suggested Answers
SOURCE: Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Posted on May 04, 2009
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
My lms 332c wont stay on tried soft reset turn it on goes off what to do?
what do you have your unit hooked to too power up straight off the battery or thru a power switch if thru a switch hook it straight to bettery
Nov 15, 2012 | Lowrance Lms 522c 5" Screen Color Internal...
My RCA D52W15 52 in. is not turning on. Please help!
Yes, it is not a good set and the situation you indicate means a short exists and the set is following the 3 strikes rule it has--it will attempt to come on 3 times and then go into shutdown.
Apr 03, 2012 | Televison & Video
Turn on and few seconds goes off
The fan is cooling the power suply and geting power from it the power suply is going bad the relay is turning the tv off to proteckt it's self.
Nov 24, 2009 | Televison & Video
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turn the unit off.
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Lowrance LMS-330C GPS Receiver Logo
65 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
