Question about Dishwashers
I am renting a house which has a BENDIX DWN 41 BX dishwasher. The dial and symbols don't mean much and am trying ot work out how to use the dishwasher, so a user manual would be fantastic.
  • 351 Answers
SOURCE: Asho D1976 Dishwasher, what do the SYMBOLS mean??!!
power button far left then heavy wash, normal ,light,and quick i think you also have economy and temp bottons.if you live in aust call 1300 00 2756 or goto www.asko.com.au hope this helps
Posted on Mar 12, 2008
SOURCE: Symbols on the Dishwasher
The circle that looks like a sunny side up egg? That's the super hot sanitary rinse.. the other symbols simply mean lots of plates only, plates with glasses, or the short section means rinse.
Posted on Jun 18, 2008
  • 100 Answers
SOURCE: dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Posted on Jan 27, 2009
  • 37 Answers
SOURCE: I need a user manual for my Electrolux dishwasher Model DX302
Call Electrolux @ 877-435-3287
Make sure you have your model/ serial # handy
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
jyackle5
  • 8197 Answers
SOURCE: I Need a user's manual for a Baumatic Dishwasher
You can get the manual here on link below.
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
Good Luck
Posted on Nov 13, 2009
Testimonial: "BRILLIANT !! THANK YOU VERY MUCH."
Bendix bdw53 dishwasher pump not working?
Don't try it at home, please contact authorized service center. It may be hazardous, Please don't use it before Authorized Service Professional fixes it.
Apr 23, 2014 | Tricity Bendix 24 in. BDW53 Free-standing...
How to use 'rinse aid'
Yes, remove that "dial" and pour in the rinse aid. Replace the dial and set it to one of those numbers (or maximum). If you use a low value and find spots on the dishes, try setting the value higher. This will increase the amount of rinse aid released during the washer cycle. The manual for another dishwasher, http://www.homedepot.com/catalog/pdfimages/4a/4a78e197-7da5-432d-b3be-e176eb727d58.pdf , can give you an idea of how this works. The rinse aid information is on page 11 of that PDF.
I hope this helps.
Apr 10, 2017 | Dishwashers
Hi I have a Tricity Bendix dishwasher model DH090. Light comes on, starts up, tablet even drops out of the holder but then the dial stops, nothing else happens. It doesn't matter which of the four...
My wife discovered the solution to this problem.
If you place large plates at the front then the flap with the cleaning tab can't open. So only place small plates at the front of the Dishwasher.
Oct 03, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Given D a b c d x y list the proper subsets of D Problem
We use the symbol ? to mean "is a subset of" and the symbol ? to mean "is not a subset of".
The subsets of D are { },{ a},{ b},{ c},{d },{x },{ y}
{ ab},{ac},{ad },{ax},{ay}
{bc },{bd},{bx},{by}
{cd},{cx},{cy}
{dx},{dy}
{xy}
Hope this solution could help you to solve your problem. Sir/Mam don't forget me to rate me up i really I appreciate what grade you have given to me. Thanks a lot and God Bless.
Jun 19, 2011 | Computers & Internet
What do the Tecnik dishwasher symbols mean? I have a unit not working with a warning light on I cant find in the manual.
The little star means you've run out of rinse-aid. See the flap that's next to your tablet dispenser, it has the same star on the lid, inside there you can refill the rinse-aid by pouring it into the tiny gap next to the dial! The dial setting allows you to change the flow of rinse-aid...the light will then go off. However, I've yet to find out what the light with the two directional arrows means! Ill post when I know!
Mar 12, 2011 | Dishwashers
I have got DWN 38 L Bendix dishwasher, problem is that during the wash cycle water starts to come under the washer. To ,me it looks like it can't take the water out.
If water is collecting under the dishwasher then there could be a few reasons.
1. door gasket is leaking - check for defect and replace if required
2. the wash or drain pump could be leaking water. Seals are not sitting properly or drain hose is cracked.
Feb 15, 2011 | Tricity Bendix 24 in. DH104 Free-Standing...
Random disconnects
Your problem is on the Cable companies side, there is nothing you can do besides making them come out to fix it. Be warned that some ISPs are known to play the blame game and pin it all on you...I used to work for Comcast and seen this happen regularly.
In short, you are looking for a connection problem in the lines around/in your house.
The long version:
The cable wires that run around the neighborhood are the main lines. Every few houses there is what is called a "tap". The tap is a little box with a few ports to connect a regular sized cable to it(the same cable you see inside your house). Fromt he tap the cable goes to your house and "should" be connected to what is called a "ground block". A ground block should have a wire going from it to some type of ground. This is to prevent an electrical shock traveling through the lines into your house and frying anything connected to it. From the ground block it should then go into a "splitter". The splitter has 1 input port for a cable line to connect to and has anywhere from 2-10 output ports. If there are unused output ports, they should be capped off to reduce signal bleeding/loss/interference.
Okay, now the fun part. From the ground block, the next step in your line should be a 2 port splitter. So it should have a cable going into it and 2 coming out. One of the 2 coming out of it should be going "directly" to your modem. If the setup is any different than I just described, your house was wired wrong and could be the culprit to your internet problem.
There is also a possibility that your "tap" is bad, I have seen it more than a few times. A low level tech can fix this.
Also, there are boxes every so often on the main lines that run on the telephone lines. They can be misconfigured and also create internet problems. These will require a higher level technician to fix.
Next possibility is that your modem itself is bad, when you schedual a trouble shooting call with your ISP, ask them to bring an extra modem with them.
Almost forgot an important one, where the cable "screws" into any port on the tap, ground block, splitter or modem...it is not snug tight and you are not getting a full signal. This is a very very very common problem. The endings that screw into things, they are called "F-Connectors" and do periodically require to be replaced.
The tech that comes out to fix your problem, if they do not have a wave length meter on them...they do not have the proper tools to diagnose your problem. An official tech of your ISP will almost always have one on him, it is the contractors that usually do not. Ask for a real tech and not a contractor to show up.
Keep calling when you experience problems. Each time you call, ask for money to be taken off your bill for your troubles. If the person on the phone says they can not do that, ask for a supervisor.
Hope this helps.
Feb 02, 2010 | Arris SURFboard® SB5101 Cable Modem
Mar 11, 2008 | Asko D1976 Built-in Dishwasher
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
