Question about Hitachi 55HDM71 55 in. HD-Ready Plasma Television
Hitachi plasma 55HDM71 When i power it on i can ear the clic from the relay when the green lignt appear, then a second later i ear the relay goes off. It is like there is no power gowing on. This monitor have approx, 8,000 hours of life Thanks
  • Hitachi Master
  • 11,800 Answers
The relay goes off because the safety system in the power source detects an overload and shuts the source down to protect it. On a tv this old the first signs of old age begin to appear. Open the tv and look for failed capacitors on the power source and the Y-sus boards, then check the voltages.
Replacement boards can be found here
http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/55HDM71/Other+Remotes.aspx
Posted on Sep 07, 2010
Remote code for 55HDM71 Hitachifor remote URC152
0279,0277. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 17, 2014 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
I have no picture. i have sound and the power light is on
This can be tricky in this set I have replaced ps, logic , sdr u and d, and I think my problem was Logic board at first. There were lights on this board that goes back and forth like the Kit car, this tells what is not working. This can be very expensive in the shop. But it's complicated also.
Dec 24, 2010 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
T V Goes on to Green Light Yet Box Stays On Red
I have an AV3000E that developed this symptom following a 5 second power cut.
I downloaded the manul, suspecting a power supply problem. The way the AV3000E works is to have a 5 volt power supply running all the time, this powers the main processor. The main processor then energises a relay (S901) by applying 5V DC between relay pins 3 and 4. The relay contacts switch rectified mains power to the main switching regulator. The replay was being energised but appeared not to be switching. While the AV3000E was connected to the mains, I carefully I connected a short between relay contacts (1 and 2) while the processor was trying to energise the relay coil. The TV burst into life. I removed the short and the TV continued to operate normally and has done so ever since. I cannot entirely rationalise why this has worked as this should not have fixed the relay, what may have happened is that the short power cut may have resulted on the some corruption of the processor non-volatile memory, and that the incorrect operation of the main relay caused the processor to reset it's internal memory.
BE WARNED, WHAT I DID WAS EXTREEMLY DANGEROUS AS THE RELAY CONTACTS I SHORTED ARE CONNECTED TO THE MAINS SUPLY - YOU ARE LIKELY TO KILL YOURSELF IF YOU DO NOT KNOW WHAT YOU ARE DOING - PLUS I TOOK THIS ROUTE AFTER ELIMINATING THE OTHER OBVIOUS PROBLEMS LIKE FAILED FUSES.
May 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
Hitachi p55h4011
if the tv is completely dead, your first step is to check the fuses in the power supply.but if you get the standby light, and nothing happens when you hit the power button, you need to call the repairman
good luck
caypianan@yahoo.com
Nov 07, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
No power
a surge occured. now no power is present. not a flick of juice when main switch is pressed.
Jul 23, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Red vertical Line on 55" Hitachi plasma
check the MAIN -Y- SUSTAIN BOARD i believe that your problem is there
good luck
caypianan@yahoo.com
Mar 16, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Hitachi 55HDM71 55 in. HD-Ready Plasma Television Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
