Question about M-Audio Delta 1010 Sound Card
Using drum triggers with M Audio Delta 1010 and Digidesign MP 7.3
My drummer wants to use triggers with his drum set using the computer. He has the M Audio Delta 1010 unit that he can send the sound from the triggers to, using 8 triggers with 8 1/4' chords. The 1010 has a USB type chord that sends the audio to the computer where his Digidesign M Powered 7.3 software takes the audio and puts them on seperate tracks. That was the way we had it set up when we were using mics. Now he wants to use triggers. (The 1010 unit also has a midi in/out). What software and hardware does he need in order to use the 1010 and the Digidesign MP7.3 software with the drum triggers. Hopefully something that digidesign or M Audio makes.
I have an alesis dm5 with ddrum triggers and I use the midi function on the 1010 to control Ezdrummer (toontrack) which is stand alone or can be used in Protools. Superiour drummer is even better which has a midi learn button
Posted on Dec 05, 2009
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
Posted on May 24, 2008
Why isn't it being detected by my win 8 ?
Try reinstalling the Audio Driver As windows 8 drivers are not available Reinstall the windows 7 driver
http://www.m-audio.com/support/download/drivers/delta-6.0.8
May 12, 2016 | M-Audio M Audio Delta 1010 Lt Sound Card
Windows 7 64 bit Ultimate SP1. Nuendo 4.2.3. 32 bit version. Delta 1010 LT Sound card. Just out of the blue I started hearing slight crackle when playing back videos, wav files etc etc. It seems to do...
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
Sep 25, 2011 | M-Audio Delta 1010 Sound Card
Where can i get a free M-audio 1010 to download?
You can download the Delta 1010 drivers from the website http://www.m-audio.com/index.php?do=support.drivers&f=736
I hope this works for you :)
Regards,
Aby
Apr 21, 2010 | M-Audio Delta 1010 Sound Card
Popping and clicking in delta 1010 playback
frequency response: 20Hz-22kHz, +/-0.3dB spacer.gif dynamic range (A-weighted): 109dB (A/D), 117dB (D/A) spacer.gif signal-to-noise ratio (A-weighted): -109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
Jul 22, 2009 | M-Audio Delta 1010 Sound Card
Hearing double voice when monitoring through delta 1010
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
Jan 07, 2009 | M-Audio Delta 1010 Sound Card
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
Clicks
try to change the clock sync in the sound card to independent
Mar 26, 2008 | M-Audio Delta 1010 Sound Card
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
Loud buzz on every output with no audio
Look in the computer music mags and look fro M-Audio dealers. Ring them up and tell them the problem your having and see how much it will cost to fix. If it's humming then it's proably broke and needs repairing. Just make sure the sampel rate isn't set too low as well
Dec 26, 2006 | M-Audio Delta 1010 Sound Card
Open Questions:
M-Audio Delta 1010 Sound Card Logo
167 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
