Question about Kenmore HE2 Plus Front Load Washer
How do I remove the drain pump filter - Kenmore HE2 Plus Front Load Washer
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2010
How to remove Zanussi ZWF14581W Filter - Drain Pump
Sometimes a larger object prevents pull out the filter and then is only solution to remove drain pump from the filter housing and remove the foreign object from opossite side.
26176372-mqizlhaqplgaehwd1f10tdku-3-0.jpg Dado
Apr 26, 2016 | Zanussi Washing Machines
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
Wont pump out water
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Feb 09, 2011 | Kenmore Dishwashers
It won't pump out the water.
Hi
Oct 25, 2010 | Frigidaire Dishwashers
Will not drain before spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance.
Daniel
Aug 30, 2010 | Washing Machines
Wont drain
Hi
Daniel
Aug 28, 2010 | Whirlpool Washing Machines
Water not pumping
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat.
Daniel
Aug 07, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
MY LG WASHING MACHINE SCREEN KEEPS ON SAYING OE
It is a long drain error and appears when the washer is not fully drained after 10 minutes of draining. It can be due to a clogged or kinked drain hose, clogged pump filter, or the pump is not working properly.
LG Front Load Washers Drain Problem Troubleshooting and Repair Guide
  1. Remove the two screws on the back of the top panel securing it to the cabinet.
  2. Slide the top panel to the back of the machine then lift it.
  3. Disconnect the wiring harness connector from the control panel.
  4. Pull the dispenser drawer out and remove the two screws under it.
  5. Lift the left side of the control panel and pull it out.
  6. Remove the four screws holding the top part of the front panel to the cabinet.
  7. Open the pump filter cover and remove the screw holding it.
  8. Insert a flat-bladed screwdriver or a putty knife in the left and right edges of the filter cover then pull it out.
  9. Remove the screw from where the pump filter cover is removed.
  10. Open the door and remove the door gasket retaining hoop by stretching the retainer spring.
  11. Peel off the door gasket into the drum.
  12. Tilt the front panel and remove the door switch wiring harness connector.
  13. Lift and remove the front panel from the cabinet.
  14. Remove the sump drain plug and drain the water in the sump into a shallow pan.
  15. Remove the sump hose from the tub by loosening the clamp holding it.
  16. Remove the drain hose from the drain pump and the recirculation hose from the recirculation pump if there's any.
  17. Remove the two screws holding the pump assembly to the cabinet.
  18. Push the pump assembly in and lift it out of the machine.
  19. Remove the pump filter from the pump housing and check it for any obstruction.
  20. Check the sump and drain hoses for any obstruction.
  21. Remove the drain pump from the housing and check the impeller for any obstruction or damage.
  22. Replace the drain pump if the impeller is damaged or if no obvious obstruction is found in the pump filter, sump hose, or drain hose.
  23. Install the new drain pump and reassemble the other parts in reverse of the disassembly steps above.
Please let me know if you need further assistance regarding this problem.
Jan 23, 2010 | Washing Machines
LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Dec 13, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Kenmore HE2 Plus Front Load Washer Logo
557 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
