Question about Emerson Fans CF705AW 52" Northwind Ceiling
I have an Emerson CF705AW with a broken speed switch Dealer sold me a Westinghouse #77021 Now I get these speeds: High, low,low,off - No medium speed Wouls switch # 77020 be correct? I nered a switch that will connect 2 wires at a time for medium Also, what colors go to what numbers on the switch? I have black, purple, brown & grey wires.
    Scholar:
  • 57 Answers
Ah.
A simple Capacitor based speed control. How many places do you have to put wires on your switch? You may have mis-wired the switch, or you have the wrong switch.
How it all works is... When you turn the fan to High, or position 1 on the switch (there's L 1 2 and 3) the power goes from 1, to the capacitor, but does not go through the capacitor, but instead goes through the second (probably gray) wire directly to the reversing switch in the switch housing. When you switch to medium (or 2) both 2 and 3 positions on the switch are supposed to be sending power through both capacitors inside of the black box. Basically, you have two capacitors, when you go to medium, both are wired in parallel to each other, but on low, only one is in the circuit. Basically, the switch you have, or have mis-wired, is putting only one capacitor in the circuit at the time on medium and low positions.
Also, do not worry, so long as you only mess with these 4 wires, you cannot blow anything up, However! When you disconnect power from the fan, BE SURE that the fan is "On" when you turn the power off to ensure the capacitor discharges as you can get a very very nasty shock from the bare wires.
Posted on Sep 23, 2010
Wiring diagrahm for 3 speed fan
Copy following link for wiring 3-speed switches:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Dec 09, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a Hampton Bay ceiling fan. I bought Westinghouse 77021 to replace the fan switch. I have black, white, yellow and blue wires inside the fan's case. Where should I connect these wires? Jane
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Mar 07, 2011 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse 3-way fan switch can not be turn off.....
I had a similar problem. A replacement Westinghouse 3-4 wire 3-speed replacement switch from Home Depot, part # 77020, is a multi-pole that did not work with my ceiling fan. There was no "off" position. I found the correct replacement switch, sold under the "Harbor Breeze" name, part # 033905, which is a single pole switch, at Lowe's, at a better price!
Feb 15, 2009 | Westinghouse Electric Ceiling Fan 3-way...
Emerson Fans CF705AW 52" Northwind Ceiling Logo
121 people viewed this question
Top Emerson Fans Dryers Experts
Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
