Question about Sony Playstation 3 (PS3) Console
Ps3 not playing blu ray on my samsung LCD
The games are working fine, but when i enter the blu ray disc tv comes with a message saying 'Mode not supported' i have tried changing the resolution settings on the ps3 but its still not working
  • 6 more comments
  • GTBandit May 30, 2008
    I seem to have the same problem with my new game "Racedriver GRID". When the disc is inserted I get the message "mode not supported". If I pop it out and insert any other game, no issue
  • reany21 Jun 08, 2008
    the games are working fine, but when i enter the blu ray disc tv comes with a message saying 'Mode not supported' i have tried changing the resolution settings on the ps3 but its still not working
  • usman0826 Jun 26, 2008
    exact same problem sent in ps3 got a new one but no luck? am io suppose to to take the samsung off the wall and return that too
  • Anonymous Jun 28, 2008
    the ps3 is working i can play games, go on PSN. but, for some reason the PS3 is just not playing the blu ray, yet plays the normal dvds.
    is there anyway that i can fix this
  • RikMak916 Jun 28, 2008
    my ps3 is playing the games and i can log on yet it doesn't play the blu rays i rent, yet it can play the normal dvd rom.
    is there any solution for this problem
  • jhtucker77 Jul 20, 2008
    My PS3 still does not work after trying the push the button and wait for 5 sec. fix.  I was able to get it to play the disc, but the video never came onto my screen.
  • pizzabagel15 Oct 19, 2008
    I am able to play PS3 games and regular DVD's but once I enter a blue ray dvd I receive a message that there are no signals
  • Anonymous Dec 19, 2008
    When trying to watch a blu-ray movie on ps3, message comes up that says "not supported mode"
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
Posted on Jan 02, 2009
Solution # 4 was on the mark. I had an earlier generation Samsung 1080p and had to turn off 24 Hz to make the TV display blu ray movies properly. What a lifesaver!
Posted on Feb 18, 2010
  • marty bruton
    marty bruton Apr 27, 2014
    thanx ur a lifesaver!
Agree with Best Solution 1, although the path you need to make this change is under Settings - Video Settings - BD 1080p 24 Hz Output (HDMI) and change it to "Off". I have an earlier Samsung 1080P LCD and it dows not support 1080P24.
Posted on Oct 10, 2009
  • marty bruton
    thanx bestvader awesome
To fix this problem, in your PS3 menu go to Setings, BD/DVD Settings then change BD 1080p 24 Hz Output (HDMI) to "Off" (you probably have it in Automatic). Try you BD movies now.
Hope it helps :)
Posted on Aug 10, 2008
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Jun 28, 2008
Playstation 3 not playing games but will play blu ray discs
Make sure that your firmware is updated correctly. Also make sure the games are the correct region for the unit you're playing on. You may have an incorrect region setup on the PS3. PS3 games are region locked, either being PAL or NTSC. If the PS3 is set to read PAL (by being set to a region that is PAL, like the UK, Europe, and Japan) it will not read or play an NTSC disc.
Misconfigured or corrupted firmware installations can also cause this problem. Furthermore, pirated games will not play, because they do not have the appropriate security key on the disc.
You can try testing this by creating a new profile on the PS3 and trying to play the games. If you can play them with the new profile, then there is a corruption with the old profile. If you can't play them in the new profile, then it could be the firmware.
Lastly you may have a blown drive. Most PS3 games are dual layer blu ray discs capable of storing large amounts of data. The blu ray drive in the PS3 uses a sequenced dual laser to read the game. If one of the laser emitters has blown, it won't read the game correctly. However, since it doesn't use both emitters to read blu ray movie disks or dvds they'll still play correctly.
Oct 04, 2014 | Sony Playstation 3 (PS3) Console
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
Why wont predators blu ray play on my ps3. all of my other blu ray discs will play but predators wont. the screen says tat the blu ray needs to be updated
go to your ps3 BD data utilites under video and delete the storage you have from the previuos discs you have played. I HAD THE SAME PROBLEM AND SFTER FOLLOWING THIS STEP THE PREDATORS DISC WORKED FINE.
Oct 23, 2010 | Sony Playstation 3 (PS3) Console
My new 3.15 ps3 won't play blu-ray but will play everything else no problem. no problems to play games or to play normal dvd's. When playing a blu-ray the UNIVERSAL part at the start of the movie plays...
f the Blu-ray Disc does not support 1080p 24Hz video mode, the video output may not display properly.
If a Blu-ray Disc movie is not loading properly or is freezing on a title screen, this may be caused by the PLAYSTATION 3 attempting to download BD-Live content from congested movie studio servers. If you experience this issue, you may choose to temporarily bypass the BD-Live content until the congestion at the movie studio servers has cleared.
Go to Settings icon (Settings) > Video Settings icon (Video Settings) > [BD Internet Connection], select "Confirm". Then reload the Blu-ray movie and the PLAYSTATION 3 will prompt you if you wish to allow the disc to access BD-Live content. Choose to not access BD-Live content to see if the movie will now load.
For some reason you seem to think this is a PS3 problem. Why do you think this is a PS3 problem? If you can play PS3 games, then I will say it is not a PS3 problem, as all PS3 games are on Blu-ray, and if you were having problems playing PS3 games, then that could account for the movie not working.
Since only the movie isn't working, I am going to say you have a defective Blu-ray disc. Did you just buy this movie, or have you viewed it before using the PS3? If you have never viewed it on the PS3, then the problem lies in the disc, and you need to take it back and have it exchanged.
If you have played the disc in the PS3 before (the PS3 you are having a problem with, not a different PS3 or Blu-ray player), or you still think it is a PS3 problem, then use the "Disc Troubleshooting" support page. Normally, if a Blu-ray movie will not play, it won't play at all, and it is because the Blu-ray laser has gone out. It sounds to me that the disc is bad, but this is only going on the information you have supplied.
Here is the Disc Troubleshooting support page mentioned above:http://playstation.custhelp.com/app/answ…
**EDIT**
Sorry, I just noticed you gave a UK link. Here is the support page for the UK. You will have to do a search on the site to find the Disc Troubleshooting page for your region.http://uk.playstation.com/support/
**EDIT**
Okay, here is your Disc Troubleshooting page for the UK:http://faq.en.playstation.com/cgi-bin/sc…
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
My panasonic blu ray wont play space odyssey 2001 the tv says mode not supported, it plays the sound but no picture all other blu ray discs play as normal. Can you help?
I did solve the puzzle what I did was to, disconnect the HDMI cable and reconnected via component video and it worked well. I am still not sure why it wouldn't play with HDMI as all my other blu ray discs played OK.The TV is a Samsung 52in lcd.
Oct 27, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Ps3 won't read disc
When Blue ray disk is placed into slot it seems like it is going to work and the screen on tv shows the entro for sony but nothing happens. Controls on controller will not function.
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Aug 08, 2007 | Sony Playstation 3 (PS3) Console
PS3 Problems with Blu-Ray Movies
I found the answer from another site. Hope it helps you: go to bd/dvd setting and set the "108024hz" option off site: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
4,121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
