Question about Brother MFC-465CN InkJet Printer
{ do not know how to insert cartridges - Brother MFC-465CN InkJet Printer
  • 6,831 Answers
Hello
OK, at the link below you will be able to download the manual. Now, you can also use it for future reference.
Click HERE to navigate to the download page.
Have a look on page 147.
Let me know if you found this helpful.
Kind regards
Andrea
Posted on Sep 07, 2010
Cannot fit the 75 and 74 ink cartridges in my 4260 printer
Make sure you insert 75 (color) on the LEFT and 74 (black) on the RIGHT. A tab in the top of each cartridge holder blocks you from inserting the incorrect cartridge.
(How Do I Know: had a hell of a time inserting the print cartridges myself, and when i finally shoved the 74 (black) in on the left, i discovered the tabs; had a hell of a time trying to pull it out after that. inserting the cartridges in the correct port, however, was a breeze.)
Oct 03, 2011 | HP Deskjet D4260 Printer
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
Inserted new cartridge but it saying "print
This can happen if you dindn't remove all the tapes from the cartridge.
Please check this and let me know if you solved
Feb 28, 2011 | Dell 924 All-in-One InkJet Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Feb 17, 2011 | Lexmark X6575 All-In-One InkJet Printer
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP printer error 10.92.02 and 10.92.01 - cartridges not engaged . . just changed the cyan cartridge and this error appeared - help
I don't know what printer you are using because a P3005N is a monochrome printer and doesn't use a cyan cartridge.
For a lot of colorlaserjets you can try the following steps. Remove all the cartridges, close all doors and power on the printer and then power it off. Insert the cartridges one by one and power the machine on and down each time you inserted a cartridge.
Feb 18, 2010 | HP LaserJet P3005n Printer
Don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Apr 13, 2009 | Lexmark X4650 InkJet Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
Brother MFC-465CN InkJet Printer Logo
20 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
