Question about Intel Motherboard
How to install a triton 79
How do i orrectly install a triton 79 to a asus m3a32 mobo the cooling plate fo the fan looks like it dont touch the cpu
    Scholar:
  • 72 Answers
It should just stick on the CPU, but I suspect that the heatpipes are hitting the plastic shroud around the socket on the motherboard. If that is the case, I believe you can remove that plastic shroud so that the cooler can settle down the extra half a centimeter and make contact with the CPU.
Since the cooler doesn't use that shroud (I don't think) then this should be ok. Is this the problem you are having? If you could provide some pictures that would be lovely.
Posted on May 14, 2008
    Novelist:
    Champion:
  • 214 Answers
Are you using the single AMD clip or are you trying to use the 2 Intel clamps? (the ASUS M3A32 mobo is an AMD platform) Sorry if I am insulting you by needing to ask this question.
Is it missing by the thickness of the Thermal Paste?
Sorry that I cannot help further, but if you need extra help, try the Triton 79 forum which can be found here:
http://vip.asus.com/forum/topic.aspx?SLanguage=en-us&model=Triton+79+Amazing&board_id=16
Good luck.
Problem: No display everything running including cpu fan, pci card everything. No error sound. Anyone please help. its a x58 chipset. I also checked that the motherboard getting hanged. like after running...
You will remove the CMOS battery and wait for 5 minutes .
Hope it will solve.
If the problem is same please change or clean the RAM with eraser and install it again.
If the problem is same please ,
http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new.
Hope this helps.
Jan 10, 2011 | ASUS P6T Deluxe Motherboard
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Computer shuts down in games, replaced Mem and PS 800W
I would check the bios and see what the shutdown temps are for the cpu as they may be set too low ( check the manuals for the cpu's as you dont want to set it too high as obviously if it does get too hot you dont want the cpu's ( processors ) to blow up or die on you.
Apr 11, 2009 | ASUS COMPUTER INTL M3A32-MVP MBD ATX...
Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
Apr 06, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Finding a cpu cooler replacement for motherboard with screwholes.
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Feb 13, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computer won't turn on.
This sounds like an overheat problem, is your cooling fan working properly, also the processor you are using is a powerful one, so needs a cooling fan much more powerful than the lesser powered athlon 64 processors.
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
ASUS cpu fan enquiry
Hi, your motherboard type dont show up on google, but its the same as the CPU, if the cpu is skt A then heatsink & fan will be for a SKT A. Same scenario if its ,775,754,939,478 etc
Have a nice christmas
John
Ps should only cost about £10
Dec 13, 2007 | ASUS (CRUXK8MH7S) CPU Cooling Kit, Cooling...
Intel Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
